Migrate Zabbix from Centos to Ubuntu
  • Qais
    • May 2021
    Hi Dears
    first I am not a Linux expert
    I have Zabbix 5.0.17 installed on Centos 7
    Since no more Centos so I am trying to migrate Zabbix5.0.17 to ubuntu22.04.1 Zabbix 6.2
    The Procedure I tried and Failed with it
    1- Prepared new fresh ubuntu22.04.1
    --------------------------------preparing the platform
    2- apt install apache2 php php-mysql php-mysqlnd php-ldap php-bcmath php-mbstring php-gd php-pdo php-xml libapache2-mod-php
    3- apt install mariadb-server mariadb-client
    4- systemctl start apache2
    5-systemctl enable apache
    6-systemctl start MariaDB
    ---------------------------------preparing the DB
    7-mysql_secure_installation​
    8-mysql -uroot -p
    9- create database zabbix character set utf8mb4 collate utf8mb4_bin;
    10-create user user@localhost IDENTIFIED by 'userpassword';
    11-grant all privileges on zabbix.* TO user@localhost;
    12-flush privileges;
    13-quit;​
    -----------------putting the mysqldump to run on the new server
    14-mysql -u root -p zabbix < /home/BACKUP/zabbix.sql
    -----------------------installing zabbix server
    15-wget https://repo.zabbix.com/zabbix/6.2/u...u22.04_all.deb
    16-dpkg -i zabbix-release_6.2-2+ubuntu22.04_all.deb
    17-apt update
    18-apt install zabbix-server-mysql zabbix-frontend-php zabbix-apache-conf zabbix-sql-scripts zabbix-agent
    ​19-zcat /usr/share/zabbix-sql-scripts/mysql/server.sql.gz | mysql --default-character-set=utf8mb4 -uzabbix -p zabbix
    after that I logged in GUI in Database connection configuration I have this error
    The Zabbix database version does not match current requirements. Your database version: 5000000. Required version: 6020000. Please contact your system administrator.
    zabbix Log file
    2369:20221107:171742.313 using configuration file: /etc/zabbix/zabbix_server.conf
    2369:20221107:171742.365 cannot use database "zabbix": its "users" table is empty (is this the Zabbix proxy database?)
    2372:20221107:171754.574 Starting Zabbix Server. Zabbix 6.2.4 (revision 885eaefa6f7).
    2372:20221107:171754.574 ****** Enabled features ******
    2372:20221107:171754.574 SNMP monitoring: YES
    2372:20221107:171754.574 IPMI monitoring: YES
    2372:20221107:171754.574 Web monitoring: YES
    2372:20221107:171754.574 VMware monitoring: YES
    2372:20221107:171754.574 SMTP authentication: YES
    2372:20221107:171754.574 ODBC: YES
    2372:20221107:171754.574 SSH support: YES
    2372:20221107:171754.574 IPv6 support: YES
    2372:20221107:171754.574 TLS support: YES
    2372:20221107:171754.574 ******************************
    2372:20221107:171754.574 using configuration file: /etc/zabbix/zabbix_server.conf
    2372:20221107:171754.673 cannot use database "zabbix": its "users" table is empty (is this the Zabbix proxy database?)
    Please could help me with this
  • Markku
    • Sep 2018
    • 1784
    ​19-zcat /usr/share/zabbix-sql-scripts/mysql/server.sql.gz | mysql --default-character-set=utf8mb4 -uzabbix -p zabbix​
    You already imported your old database before that, don't try to import the Zabbix default schema anymore.
    Also, don't try to use the GUI before the database has been upgraded, so start the new Zabbix server first, let it update the database, then go to GUI.
    Markku
    • superlava
      • Nov 2021
      • 26
      Originally posted by Qais
      Hi Dears
      8-mysql -uroot -p
      13-quit;​
      17-apt update
      zabbix Log file
      Migrating to Rocky Linux or Alma Linux would be recommended here as both are derived from RHEL.
