Time not correct in graphs Zabbix 6.2.3 Redhat 8.6
  • mh80
    • Nov 2022
    I've seen more topics with the same issue but none fixed the issue for me. The time in the graphs are 1 hour in front. I have checked:
    /etc/localtime -> /usr/share/zoneinfo/Europe/Stockholm
    php-fpm.d/zabbix.conf = php_value[date.timezone] = "Europe/Stockholm" (Not commented out)
    php.ini = date.timezone = "Europe/Stockholm" (Not commented out)
    hwclock = 2022-11-08 16:55:59.010006+01:00
    Of course all services restarted after adjustments.
    In the frontend I've set the time to "Europe/Stockholm" (Adminstration -> General -> GUI)
    Running Redhat 8.6
    Installed Zabbix 6.2.3
    Are there any other files that may need to be checked?
    Thanks...
  • tim.mooney
    • Dec 2012
    • 1436
    Good thoughts on the stuff you checked, especially the php-fpm.d/zabbix.conf.
    For Red Hat 7.0 and later, I would probably also verify that 'timedatectl' agrees.
    Did you recently go through a daylight saving time (DST) to non-DST transition?
    • mh80
      • Nov 2022
      Two weeks ago we went through the daylight saving shift "Oct 28th"
      Out put of timedatectl
      timedatectl
      Local time: Wed 2022-11-09 09:49:45 CET
      Universal time: Wed 2022-11-09 08:49:45 UTC
      RTC time: Wed 2022-11-09 08:49:45
      Time zone: Europe/Stockholm (CET, +0100)
      System clock synchronized: yes
      NTP service: active
      RTC in local TZ: no
