Dynamic enabled items ?
  • Orwel
    • Nov 2022
    I want to collect some hardware items (power consumption, fan status, ...) but only at bare metal hosts. Therefore i created an item "isvirtual" which checks if this system is running in a vm or bare metal, however i dont find a way to dynamicaly enable/disable items based on the value of anaother item. I tried something with discovery rules but found no way to create discoevery rules from item prototypes.
    Is there a way to configure this use case in zabbix?​
  • Semiadmin
    • Oct 2014
    • 1626
    • Orwel
      • Nov 2022
      I dont think singleton discovery solves my usecase so i try to clarify.
      My optimal solution would be:
      if baremetal(discovery) => get bmc-data(as item prototype)
      --> from bmc data discover powersupplies (dependent discovery from bmc-data as mater item)
      ----> get power consumption
      --> from bmc data discover fans
      ----> get rpm
      In this scenario i need to create discovery rules (for fan, powersupplies,...) from an item prototype as master item, but i dont see how singleton discovery can help me here.
      If i create bmc-data as a normal(non discovered) item all works as exspected but on non bare metal hosts i get lots of errors (in log) and invalid items so i need a way to disable the bmd-data masteritem on non bare metal hosts.​
        Sounds like "overrides" ... if "{#ISVIRTUAL}" exists, then stop processing or do not discover...
