Hi.
I realise this is probably seeming backwards to what people normally monitor, but is it currently possible to monitor connected displays to a system. I have some systems that MUST have a display connected at all times.
For example,
If this happens, I need to report that in to zabbix.
I'm not sure if it's possible over SNMP or natively, but ideally I'd like to avoid running user scripts where possible (if I have to, I have to). If anyone has any ideas, it would be very much appreciated.
For example,
Screen 0: minimum 320 x 200, current 1024 x 768, maximum 16384 x 16384
DP-1 disconnected primary (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
HDMI-1 disconnected (normal left inverted right x axis y axis)
