system.hw.chassis
  • orelaknin
    • Nov 2022
    system.hw.chassis
    Hi all,
    I'm new to Zabbix and i tried to pull a agent MB serial number, i tried with system.hw.chassis and it only displayed "desktop", after a quick check i found out the MB serial is located in dmidecode but not under "chassis" is under "base borad".
    Also i want to pull the CPU id.
    My question is if i have the option to create a new key that checks the base board contact instead of the chasis contact.​
