Hi!
I have a 6.0 LTS Zabbix system with PostgreSQL 14.5 and TimeScaleDB 2.8.1.
On the Zabbix web interface, I see an entry like this in the System information:
My Housekeeping settings:
I see this in the database:
Do you have any ideas what could be the problem?
tnwzabbixdb=# SELECT pg_size_pretty(before_compression_total_bytes) as "before compression",pg_size_pretty(after_compression_total_bytes) as "after compression" FROM hypertable_compression_stats('trends'); before compression | after compression
(1 row)
tnwzabbixdb=# SELECT pg_size_pretty(before_compression_total_bytes) as "before compression",pg_size_pretty(after_compression_total_bytes) as "after compression" FROM hypertable_compression_stats('trends_uint');
(1 row)
tnwzabbixdb=# SELECT pg_size_pretty(before_compression_total_bytes) as "before compression",pg_size_pretty(after_compression_total_bytes) as "after compression" FROM hypertable_compression_stats('history');
120 MB | 9112 kB
(1 row)
tnwzabbixdb=# SELECT pg_size_pretty(before_compression_total_bytes) as "before compression",pg_size_pretty(after_compression_total_bytes) as "after compression" FROM hypertable_compression_stats('history_uint');
64 MB | 3440 kB
(1 row)
tnwzabbixdb=# SELECT pg_size_pretty(before_compression_total_bytes) as "before compression",pg_size_pretty(after_compression_total_bytes) as "after compression" FROM hypertable_compression_stats('history_str');
328 kB | 192 kB
(1 row)
tnwzabbixdb=# SELECT pg_size_pretty(before_compression_total_bytes) as "before compression",pg_size_pretty(after_compression_total_bytes) as "after compression" FROM hypertable_compression_stats('history_text');
432 kB | 384 kB
(1 row)
tnwzabbixdb=# SELECT pg_size_pretty(before_compression_total_bytes) as "before compression",pg_size_pretty(after_compression_total_bytes) as "after compression" FROM hypertable_compression_stats('history_log');
(0 rows)
tnwzabbixdb=# SELECT * FROM timescaledb_information.jobs;
job_id | application_name | schedule_interval | max_runtime | max_retries | retry_period | proc_schema | proc_name | owner | scheduled | config
| next_start | hypertable_schema | hypertable_name | check_schema | check_name
1 | Telemetry Reporter [1] | 24:00:00 | 00:01:40 | -1 | 01:00:00 | _timescaledb_internal | policy_telemetry | postgres | t |
| 2022-11-16 03:29:34.028528+01 | | | |
1000 | Compression Policy [1000] | 1 day | 00:00:00 | -1 | 01:00:00 | _timescaledb_internal | policy_compression | zabbix | t | {"hypertable_id": 1, "compress_after"
: 612000} | 2022-11-15 16:54:33.876362+01 | public | history | _timescaledb_internal | policy_compression_check
1001 | Compression Policy [1001] | 1 day | 00:00:00 | -1 | 01:00:00 | _timescaledb_internal | policy_compression | zabbix | t | {"hypertable_id": 2, "compress_after"
: 612000} | 2022-11-15 16:54:33.311821+01 | public | history_uint | _timescaledb_internal | policy_compression_check
1002 | Compression Policy [1002] | 1 day | 00:00:00 | -1 | 01:00:00 | _timescaledb_internal | policy_compression | zabbix | t | {"hypertable_id": 5, "compress_after"
: 612000} | 2022-11-15 16:54:31.80317+01 | public | history_str | _timescaledb_internal | policy_compression_check
1003 | Compression Policy [1003] | 1 day | 00:00:00 | -1 | 01:00:00 | _timescaledb_internal | policy_compression | zabbix | t | {"hypertable_id": 4, "compress_after"
: 612000} | 2022-11-15 16:54:31.816562+01 | public | history_text | _timescaledb_internal | policy_compression_check
1004 | Compression Policy [1004] | 1 day | 00:00:00 | -1 | 01:00:00 | _timescaledb_internal | policy_compression | zabbix | t | {"hypertable_id": 3, "compress_after"
: 612000} | 2022-11-15 16:54:31.785696+01 | public | history_log | _timescaledb_internal | policy_compression_check
1005 | Compression Policy [1005] | 1 day | 00:00:00 | -1 | 01:00:00 | _timescaledb_internal | policy_compression | zabbix | t | {"hypertable_id": 6, "compress_after"
: 612000} | 2022-11-15 16:54:31.754771+01 | public | trends | _timescaledb_internal | policy_compression_check
1006 | Compression Policy [1006] | 1 day | 00:00:00 | -1 | 01:00:00 | _timescaledb_internal | policy_compression | zabbix | t | {"hypertable_id": 7, "compress_after"
: 612000} | 2022-11-15 16:54:31.737346+01 | public | trends_uint | _timescaledb_internal | policy_compression_check
(8 rows)
tnwzabbixdb=# SELECT * FROM timescaledb_information.job_stats;
hypertable_schema | hypertable_name | job_id | last_run_started_at | last_successful_finish | last_run_status | job_status | last_run_duration | next_start | total_runs
| total_successes | total_failures
public | history | 1000 | 2022-11-14 16:54:33.013436+01 | 2022-11-14 16:54:33.876362+01 | Success | Scheduled | 00:00:00.862926 | 2022-11-15 16:54:33.876362+01 | 11
| 11 | 0
public | history_log | 1004 | 2022-11-14 16:54:31.768171+01 | 2022-11-14 16:54:31.785696+01 | Success | Scheduled | 00:00:00.017525 | 2022-11-15 16:54:31.785696+01 | 22
| 11 | 11
public | history_str | 1002 | 2022-11-14 16:54:31.765535+01 | 2022-11-14 16:54:31.80317+01 | Success | Scheduled | 00:00:00.037635 | 2022-11-15 16:54:31.80317+01 | 11
| 11 | 0
public | history_text | 1003 | 2022-11-14 16:54:31.775828+01 | 2022-11-14 16:54:31.816562+01 | Success | Scheduled | 00:00:00.040734 | 2022-11-15 16:54:31.816562+01 | 11
| 11 | 0
public | history_uint | 1001 | 2022-11-14 16:54:32.635166+01 | 2022-11-14 16:54:33.311821+01 | Success | Scheduled | 00:00:00.676655 | 2022-11-15 16:54:33.311821+01 | 11
| 11 | 0
public | trends | 1005 | 2022-11-14 16:54:31.736801+01 | 2022-11-14 16:54:31.754771+01 | Success | Scheduled | 00:00:00.01797 | 2022-11-15 16:54:31.754771+01 | 19
| 11 | 8
public | trends_uint | 1006 | 2022-11-14 16:54:31.718066+01 | 2022-11-14 16:54:31.737346+01 | Success | Scheduled | 00:00:00.01928 | 2022-11-15 16:54:31.737346+01 | 11
| 11 | 0
| | 1 | 2022-11-15 05:27:38.421405+01 | -infinity | Failed | Scheduled | 00:00:03.107123 | 2022-11-16 03:29:34.028528+01 | 26
| 0 | 26
(8 rows)
tnwzabbixdb=# select * from hypertable_compression_stats('history_uint');
total_chunks | number_compressed_chunks | before_compression_table_bytes | before_compression_index_bytes | before_compression_toast_bytes | before_compression_total_bytes | after_compression_table_bytes |
after_compression_index_bytes | after_compression_toast_bytes | after_compression_total_bytes | node_name
12 | 3 | 30720000 | 36560896 | 0 | 67280896 | 278528 |
81920 | 3162112 | 3522560 |
(1 row)
tnwzabbixdb=# SELECT * FROM timescaledb_information.chunks where is_compressed=true;
hypertable_schema | hypertable_name | chunk_schema | chunk_name | primary_dimension | primary_dimension_type | range_start | range_end | range_start_integer | range_end_integer | is_compres
sed | chunk_tablespace | data_nodes
public | history_uint | _timescaledb_internal | _hyper_2_1_chunk | clock | integer | | | 1667520000 | 1667606400 | t
public | history | _timescaledb_internal | _hyper_1_2_chunk | clock | integer | | | 1667520000 | 1667606400 | t
public | history_str | _timescaledb_internal | _hyper_5_3_chunk | clock | integer | | | 1667520000 | 1667606400 | t
public | history_text | _timescaledb_internal | _hyper_4_6_chunk | clock | integer | | | 1667520000 | 1667606400 | t
public | history_uint | _timescaledb_internal | _hyper_2_7_chunk | clock | integer | | | 1667606400 | 1667692800 | t
public | history | _timescaledb_internal | _hyper_1_8_chunk | clock | integer | | | 1667606400 | 1667692800 | t
public | history_str | _timescaledb_internal | _hyper_5_9_chunk | clock | integer | | | 1667606400 | 1667692800 | t
public | history_text | _timescaledb_internal | _hyper_4_10_chunk | clock | integer | | | 1667606400 | 1667692800 | t
public | history_uint | _timescaledb_internal | _hyper_2_11_chunk | clock | integer | | | 1667692800 | 1667779200 | t
public | history | _timescaledb_internal | _hyper_1_12_chunk | clock | integer | | | 1667692800 | 1667779200 | t
public | history_str | _timescaledb_internal | _hyper_5_13_chunk | clock | integer | | | 1667692800 | 1667779200 | t
public | history_text | _timescaledb_internal | _hyper_4_14_chunk | clock | integer | | | 1667692800 | 1667779200 | t
(12 rows)
tnwzabbixdb=#
