using macros in Executed script
  • nikita_lnx
    • Jun 2022
    • 10
    Hello! I need some help with issue.
    I've created a template with some macro and Item
    Then I try to use it with host (template was attached to this host). But it is not working
    Is it possible to use macro like in my example {$WEBSITENAME} in Exectudet script via SSH by Template?
    Without macro if I put any website it works fine.
    Thank you!
  • Answer selected by nikita_lnx at 16-11-2022, 16:36.
    cyber
    • 4970
    You should be able to use "user macros" in ssh script..
    Items / item prototypes
    In an item or an item prototype configuration, user macros can be used in the following fields:
    SSH agent:
    Username
    Public key file
    Private key file
    Password
    Script​​
      • 4970
      SSH agent:
      Username
      Public key file
      Private key file
      Password
      Script​​
      • nikita_lnx
        • Jun 2022
        • 10
        Thank you for your help! Now it's working
        For other users:
        Go to Admiistration - General - Macros and set the Macro value there instead of template level
          • 4970
          Setting global macros just makes them available for everyone and everywhere. In my mind this should be avoided You can set them in template or even on host level.
