Mass update inventory
  • poessibility
    • Oct 2022
    Good morning!
    We have > 4k devices, where we can't install the agent (SOC displays) - the monitoring is software driven by an external script via the API.
    The information we get from this script is used to create a device, to assign a hostgroup and a template.
    I would now like to update the inventory with e.g. mail address and customer site.
    Is there a way to import this information from a csv file to existing hosts? Zabbix Version is 6 LTS
    Thank you!
  • guille.rodriguez
    • Jun 2022
    • 120
    CSV + Bashscript (for loop) + Zabbix Api
      CSV -> (insert your favourite scripting language here) -> API..
      • poessibility
        • Oct 2022
        Well ... thank you :-)
        I was hoping there would be a function for this without having to deal with json API and such.
          If each of your hosts has a file with the appropriate info, you can add couple of items to pull that info and populate inventory...
