Hi
We are migrating from zabbix 4.0.34 to Zabbix 6.2.3
We have installed a new infrastructure and the zabbix server is mounted in docker but the database is on a separate server (maria DB 10.7.7)
At first it was fine, but now we have the "Utilization of preprocessing manager processes over 75%" alert that appears regularly and Preprocessing queue size keeps increasing. We are often forced to restart zabbix. We also notice that some items are not refreshed as they should be (delay in each check).
At the moment we have 283 hosts and 57287 items. Performance index is 434.59 new values per second.
The server is a VM with 20GB of ram and 12vCPU.
The database is on a server with 20GB of RAM and 6 vCPU
We don't have enough resources. We tried to play with the server configuration, but nothing happens, the alert reappears.
Here is the current configuration.
We also configured the database engine because we had IOwait. Here is the configuration of mariadb
We don't know what parameters to play with and why we can't stabilize the platform. Zabbix server: The preprocessing queue never goes down...we are currently at "Preprocessing queue: 753205"
If someone can help us?
ulimits:
nproc: 65535
nofile:
soft: 20000
hard: 40000
deploy:
resources:
limits:
cpus: '8'
memory: 12G
reservations:
cpus: '2'
memory: 1G
# ZBX_LISTENIP= # ZBX_LISTENBACKLOG= # ZBX_HISTORYSTORAGEURL=http://elasticsearch:9200/ # Available since 3.4.5 # ZBX_HISTORYSTORAGETYPES=uint,dbl,str,log,text # Available since 3.4.5 # ZBX_ALLOWUNSUPPORTEDDBVERSIONS=0 # Available since 6.0.0 # ZBX_DBTLSCONNECT=required # Available since 5.0.0 # ZBX_DBTLSCAFILE=/run/secrets/root-ca.pem # Available since 5.0.0 # ZBX_DBTLSCERTFILE=/run/secrets/client-cert.pem # Available since 5.0.0 # ZBX_DBTLSKEYFILE=/run/secrets/client-key.pem # Available since 5.0.0 # ZBX_DBTLSCIPHER= # Available since 5.0.0 # ZBX_DBTLSCIPHER13= # Available since 5.0.0 # ZBX_AUTOHANODENAME=fqdn # Allowed values: fqdn, hostname. Available since 6.0.0 # ZBX_HANODENAME= # Available since 6.0.0 # ZBX_AUTONODEADDRESS=fqdn # Allowed values: fqdn, hostname. Available since 6.0.0 # ZBX_NODEADDRESSPORT=10051 # Allowed to use with ZBX_AUTONODEADDRESS variable only. Available since 6.0.0 # ZBX_NODEADDRESS=localhost:10051 # Available since 6.0.0 # ZBX_DEBUGLEVEL=3 ZBX_STARTPOLLERS=50 # ZBX_IPMIPOLLERS=0 #ZBX_STARTPREPROCESSORS=100 ZBX_STARTPOLLERSUNREACHABLE=20 # ZBX_STARTTRAPPERS=5 # ZBX_STARTPINGERS=5 # ZBX_STARTDISCOVERERS=1 ZBX_STARTHTTPPOLLERS=5 # ZBX_STARTHISTORYPOLLERS=5 # Available since 5.4.0 # ZBX_STARTTIMERS=1 # ZBX_STARTESCALATORS=1 # ZBX_STARTALERTERS=3 # Available since 3.4.0 # ZBX_STARTLLDPROCESSORS=2 #ZBX_JAVAGATEWAY_ENABLE=true # ZBX_JAVAGATEWAY=zabbix-java-gateway # ZBX_JAVAGATEWAYPORT=10052 #ZBX_STARTJAVAPOLLERS=5 ZBX_STARTVMWARECOLLECTORS=3 #ZBX_VMWAREFREQUENCY=60 #ZBX_VMWAREPERFFREQUENCY=60 ZBX_VMWARECACHESIZE=64M #ZBX_VMWARETIMEOUT=10 ZBX_ENABLE_SNMP_TRAPS=true # ZBX_SOURCEIP= # ZBX_HOUSEKEEPINGFREQUENCY=1 # ZBX_MAXHOUSEKEEPERDELETE=5000 # ZBX_PROBLEMHOUSEKEEPINGFREQUENCY=60 # ZBX_SENDERFREQUENCY=30 ZBX_CACHESIZE=512M # ZBX_CACHEUPDATEFREQUENCY=60 # ZBX_STARTDBSYNCERS=4 # ZBX_HISTORYCACHESIZE=16M # ZBX_HISTORYINDEXCACHESIZE=4M # ZBX_HISTORYSTORAGEDATEINDEX=0 ZBX_TRENDCACHESIZE=16M ZBX_TRENDFUNCTIONCACHESIZE=32M ZBX_VALUECACHESIZE=32M ZBX_TIMEOUT=30 # ZBX_TRAPPERTIMEOUT=300 # ZBX_UNREACHABLEPERIOD=45 # ZBX_UNAVAILABLEDELAY=60 # ZBX_UNREACHABLEDELAY=15
innodb_autoextend_increment = 256 innodb_buffer_pool_size = 6G innodb_flush_log_at_trx_commit = 2 innodb_flush_method = O_DIRECT innodb_old_blocks_time = 1000 innodb_open_files = 2048 innodb_stats_on_metadata = OFF join_buffer_size = 262144 max_allowed_packet = 32M max_connect_errors = 10000 max_connections = 1000 max_heap_table_size = 134217728 query_cache_type = 0 query_cache_size = 0 slow-query-log = ON table_open_cache = 2048 thread_cache_size = 4 tmp_table_size = 134217728 wait_timeout = 86400
