Users can't edit their own media
  • jamesc
    • Feb 2016
    I'm running Zabbix 3.0.1 on CentOS7 using the packages from Zabbix's repo.
    I can add media to users as a Super Admin, but normal Users and Admins cannot modify their own media (via the profile link in the top right corner). When they click the little person icon ,and then "media", they can see what's configured, enable, disable and remove media. However, clicking "add" or "edit" brings them to a page that says: "Access denied [...] You have no permissions to access this page [...]"
    Is this intended behavior? A bug? Or have I configured something incorrectly? In any case, is there a way to change it to allow them to modify their own media (other than mucking around in the code)?
    Thanks,
    James
