Copy dashboard to template dashboard?How ?
  • tomashevic
    • Nov 2022
    How to transfer already made dashboard from monitoring to template dashboard?
    IIRC, you cannot do that.
    • tomashevic
      • Nov 2022
      But, how to duplicate dashboard or copy it , ie. when i have 10,30, 40+ same devices, and i want to have separate dashboard for each ?
      • Atsushi
        • Aug 2013
        • 2028
        Instead of creating separate dashboards for hosts, why not create dashboards in templates? I don't know how to copy from already created dashboard to template dashboard.
        • tomashevic
          • Nov 2022
          Because i already made huge dashboard, and i don't want,lose time to recreating it again.But this is maybe correct way you suggesting me, everything must be in template , even dashboard, before i add any host.
          • Atsushi
            • Aug 2013
            • 2028
            I don't think there is a way to copy it. But, I have another suggestion.
            Dynamic items can be set depending on the widgets used in the dashboard. If the dashboard consists only of widgets that support this, by enabling Dynamic items in each widget, you can switch the contents of each widget by selecting the host from the pulldown at the top of the dashboard.
