Services and SLAs, mostly ping - easier way to configure?
  • phial63
    • Nov 2022
    Running Zabbix 6.0.10 and trying to get Services and SLAs working for a system with 36 hosts, hosts are mainly simple ping check, with 8 hosts using SNMP across a mix of windows and linux servers and network switches. A similar network will be built at a new location.
    I've managed to get some aspect of SLAs working, however I have had to manually add a child for every host which is tedious, even more so when I had to manually add tags to each host.
    Have added some images of how I have configured it so far.
    However with SNMP servers, if a disk utilization gets high it counts as an outage so I need to find a way to only use ping for the SNMP servers.
    Have a feeling there is a simpler way to get the SLA % for the complete system and SLA % for each host.
    A bit out of my depth here and happy for any help.​
Name:	parent service.png
Name:	parent service - tags.png
Name:	parent service  - child services.png
Name:	child service as simple check via ping only.png
Name:	child service as simple check via ping only - tags.png
