Data Overview Missing Host
  • highway_fixer_man
    • Jun 2022
    • 35
    I have a dashboard which contains the deprecated Data Overview widget.
    It was working just fine last night - but this morning - one host is missing its data on the Data Overview widget.
    The host has the data in "latest data" and it is recent data.
    If I remove the faulty host, and readd it - then ANOTHER, DIFFERENT host, looses its data on the widget, although it still has it in the "latest data" etc.
    Can anyone tell me why that might be?
    I have tried removing and readding the hosts, but that just moves the issue to another host. I have tried restarting Zabbix Server, and that made no change.
    Any help appreciated.
    I have obfuscated the fields, but they are just the hostname (1st column) with various versions of our software on them. The blank line is my concern - if I remove that "bad" host, another one just looses its data, even thought it is still there in "latest data"
  • Answer selected by highway_fixer_man at 24-11-2022, 16:03.
    highway_fixer_man
    • Jun 2022
    • 35
    I eventually managed to find a way to use "Top Hosts" by breaking my hosts down into smaller groups - as the limit is 100 hosts on that widget.
    It works - although it is a small compromise. Luckily it lines up with an administrative requirement.
    If anyone needs help setting that up, let me know and I will explain here as best I can, although it is rather simple.
    Basically - there is a way forward without "Data Overview" - so no need to panic. ​
    • highway_fixer_man
      • Jun 2022
      • 35
      Just want to add - how is this Data Overview widget being deprecated? This makes no sense - no other widget can display this info.
        • 4969
        Top Hosts widget is, what they suggest to use instead... It would almost do the trick, if they would add possibility to order data by "hostname" column (if you look into widget, then you probably understand, what I mean), but they only allow based on some item value...
        • highway_fixer_man
          highway_fixer_man commented
          Yes, I read about that as a replacement, but it actually is not suitable for my needs at all unfortunately.
          This particular widget (Data Overview) is easily the most useful to me - I cant understand why it would be deprecated.
      • highway_fixer_man
        • Jun 2022
        • 35
