Cannot see TrueNAS Scale Network Interfaces in Zabbix
  • ClintonITWorks
    • Nov 2022
    I have tried every modification to the template that I can think of to rectify this issue, but to no avail. For reference I am running Zabbix 6.2.4 and TrueNAS Scale 22.02.4. As far as I can tell, everything else is discovered just fine, only the network traffic and interfaces will not show in Zabbix.
  • ClintonITWorks
    • Nov 2022
    Update: It turns out that ZVOL will not show in Zabbix either. I am having similar issues with my proxmox host monitoring as well, though it is slightly different. With the TrueNAS system, a singly template is having issues collecting all of the data it should be, while I believe the proxmox template and linux templates are conflicting with each other, but there is data collected by each that the other doesn't have that I would like to try and have on my dashboard.
    • ClintonITWorks
      • Nov 2022
      I am still having data collection issues with the TrueNAS template, but I have solved the issue with proxmox. This may be a round about way to fix it, but it's what I came up with. I created two separate hosts for the same server each using one of the two templates, and then just added the respective widgets to the dashboard. There may be a better way to do this, but for know it is working. Again, though. I have NOT solved the data collection issue with the TrueNAS template, and could still very much use some help with that one.
