Is't web-deps dependence on web-database in zabbix 6.0.10?
  • ejzhang
    • Apr 2021
    A dependency error was encountered when i offline install zabbix 6.0.10 with rpm, It's web-deps dependence on web-database, but i can't find zabbix-web-database-6.0.10*.rpm in zabbix official repository.
    Please ask me how to solve it​, thanks very much!
ID:	454996Click image for larger version
  • tim.mooney
    • Dec 2012
    • 1436
    Look for 'zabbix-web-mysql' or 'zabbix-web-pgsql', depending upon which of those backend databases you're using.
    With RPM, the person creating the packages can create virtual dependencies and make it so that multiple alternate versions of real packages provide the needed virtual dependency.
    • ejzhang
      • Apr 2021
      Sorry, i don't understand, and i don't known how to solve it.
      I always installed MySQL 8.0.31 community version, PHP 8.1.13, MySQL driver for PHP, so how i to do next? thanks very much!
      • tim.mooney
        • Dec 2012
        • 1436
        You wrote that you are doing an "offline install", so you must have downloaded multiple packages from repo.zabbix.com and copied them somehow to the offline server. In addition to the 'zabbix-web-deps' package that you downloaded from repo.zabbix.com, you also need to download 'zabbix-web-mysql'. Then install them at the same time:
        # yum install zabbix-web-deps zabbix-web-mysql
        • ejzhang
          • Apr 2021
          Thank you first! I downloaded all rpm packages from repo.zabbix.com, and i installed zabbix-server-mysql, zabbix-web, zabbix-web-service, zabbix-sql-scripts, zabbix-selinux-policy, but there's a depending error when i install zabbix-web-deps.Click image for larger version
          • ejzhang
            • Apr 2021
            Yes, I see. the zabbix-web-deps and zabbix-web-mysql must be install together!
            Thank you very much!
            • Azzam
              • Dec 2022
              Thank you! It solves my problem too
