Remote commands via proxy
  • LenR
    • Sep 2009
    • 1010
    I seem to remember in the past where action remote commands could be sent via the proxy to the host instead of only from the server. I can't seem to find anything on the subject. I see "EnableRemoteCommands is an option in the proxy config, but I don't really see what it allows.
    Is it possible to have an action remote command sent via the proxy?
  • Markku
    • Sep 2018
    • 1784
    I believe you mean this (after Create script button):
    Click image for larger version  Name:	image.png Views:	0 Size:	40.7 KB ID:	455156
    Markku
    • LenR
      • Sep 2009
      • 1010
      Not exactly, wouldn't that run a script on the proxy related to the action's host? What I remember would route the remote command to the host via the proxy, for cases when the server can't get there due to network restrictions.
      I guess the script on the proxy could do zabbix_get -s {HOST.HOST} -k system.run[some_script] but that is convoluted.
      • Markku
        • Sep 2018
        • 1784
        Isn't "Execute on: Zabbix agent" then the correct option in the script configuration?
        Markku
        • LenR
          • Sep 2009
          • 1010
          Markku
          Yes, but the zabbix server must be able to send the command to port 10050 of the agent. For some proxy-monitored hosts, it can't, but the proxy could.
          • Markku
            • Sep 2018
            • 1784
            Oh, ok, I thought it is the managing component (proxy) that sends the command to the agent.
            Markku
            • LenR
              • Sep 2009
              • 1010
              It was originally, but that's the hole in my memory, I thought they HAD setup some way to route commands via the proxy, but I can't find it in the doc. Unless now ALL commands go via the proxy.
              • Markku
                • Sep 2018
                • 1784
                An active proxy checks in to the server every second (!) just to find out if there are any tasks to execute, so I wonder how that all really works now.
                Markku
                • LenR
                  • Sep 2009
                  • 1010
                  It may be really old.... https://www.zabbix.com/documentation...hrough-proxies
                  I think all remote commands marked "Zabbix Agent" are routed via the proxy for proxy-monitored hosts.
