doubt: snmpv3 macro
  • Yu_mib
    • Oct 2020
    • 10
    doubt: snmpv3 macro
    How do I configure snmpv3 macros? I currently use Zabbix version 3.4.14.
    When I use the following command "snmpwalk -v3 -a SHA -A password -x DES -X password -l authPriv -u user localhost" I get the information. But when I put the communication problem macros. {$SNMP_PRIV} password {$SNMP_SECNAME}​ user
    For snmpv2 using the macro "{$SNMP_COMMUNITY}" works.
  • superlava
    • Nov 2021
    • 26
    Have you tested with actual values in host rather than macro? and Have you declared global macros for these?
    • Yu_mib
      Yu_mib commented
      How do I do that?
    • superlava
      superlava commented
      You can setup global macro under Administration and General. To test actual values, you can update the SNMP values under SNMP v3 interface.
