What is proper way to define trigger expression for two consecutive measurements
  • markosa
    • Aug 2022
    • 106
    Hi all,
    I've been trying to define trigger expression which would trigger only when two consecutive (snmp polled)values are below threshold. My current solution is like: last(/device1/item1[{#INDEX},2])<last(/device1/threshold1[{#INDEX}]) and last(/device1/item1[{#INDEX},2],#2)<last(/device1/threshold1[{#INDEX}])
    I've tried min() with time value larger than two polls but its not helping since it just takes lowest value and trigger fires...
    Values are like(most recent first): 10, 15, 20, 10, 15, 18 and so on, threshold is set to (read from device) 15 and if two consecutive values are below threshold, trigger should fire.
    Is my current solution only way solve this?​
  • Answer selected by markosa at 01-12-2022, 07:19.
    Markku
    • Sep 2018
    • 1784
    max(/host/item,#2) < your_threshold
    will trigger if the last two values are both below the threshold value.
    Markku
    • superlava
      superlava commented
      Yes, This trigger will fire when last values are less than threshold. You can also use avg here.
  • superlava
    • Nov 2021
    • 26
    taking average of 2 values will solve your issue.
    • markosa
      • Aug 2022
      • 106
      Yes, avg() is one way but it causes another problem, you need to define window from where to look and in case update interval is changed, trigger needs to be changed...
      • superlava
        • Nov 2021
        • 26
        How often this item gets updated? Based on that you can set the trigger.
        Further, You can set to check latest last values by appending # to time. Example avg(Key, #10)​. will revert avg of last 10 values.
        Hope this help.
        • Markku
          • Sep 2018
          • 1784
          Markku
          • superlava
            superlava commented
        • Markku
          • Sep 2018
          • 1784
          Average does not work here:
          Example: threshold is 10, values are 7 and 11. max(#2) is 11 (not triggered, ok), avg(#2) is 9 (triggered, but not correct)
          Markku
          • superlava
            superlava commented
            Thank You Markku. I was considering binary values only. I forgot about range of a values. markosa Go with max only
