Phantom proxy configuration - how do I remove it?
  • lzvtmxwk
    • Jan 2020
    I have Zabbix 6.2 in server mode which was upgraded from 3.2 a while back. My 3.2 had a proxy configured but that proxy has since gone away. Eventhough I've removed any traces of the proxy in the Zabbix web UI, Zabbix is still trying to use it. I keep getting these messages in the zabbix_server.log:
    cannot parse proxy data from active proxy at "REDACTED-IP-ADDRESS": proxy "REDACTED-HOST-NAME" not found
    I've searched through the MySQL database looking for the IP address and the host name but I cannot find any traces of it. I've searched through every configuration file for both and I also cannot find any traces of it. Does anyone have any suggestions on how to stop it trying to communicate with this long gone proxy?
  • Markku
    • Sep 2018
    • 1784
    That message looks like you still have a proxy at REDACTED-IP-ADDRESS​ that keeps connecting to the Zabbix server. Go and hunt for the server that is running the Zabbix proxy.
    Markku
    • lzvtmxwk
      • Jan 2020
      Hi. I think you're right. I did a tcpdump and read it back in Wireshark, and the host that's sending the first SYN packet (i.e. the instigator) is the remote system and not my Zabbix server. Thanks,
