is there any possibility to get for a discovered trigger the according template.
In the GUI you can see it by clicking on the trigger and moving to trigger_prototypes.php.
What I want:
I need to get a list of all triggers from a hostgroup with their correlating template description. This has to be generated automatically.
What I already did:
- Use trigger.get -> group with selecTrigger for getting all triggers.
- Read state of triggger 0/4 for normal or discovered
- Checking for templateid or use hosts->hostid to get template
- If trigger is discovered - use triggerprototype.get with hosts->hostid
But there is no link to the real template id.
Thanks,
Oliver
What I want:
What I already did:
Thanks,
Oliver
