zabbix-agent do not starting
  • zoran
    • Nov 2022
    Hello everybody
    Can somebody help me with Zabbix Server. I installed on my Ubuntu machine a couple day ago, but from yesterday Zabbix does not working. I can login but have message zabbix-server not running. When I checked all services with command service --status-all, I saw that service zabbix-server has minus, not plus.
Name:	zabbix-server error.png
    You know that screenshot can be done only for active window also (ctrl+alt+printScr)? and just part of it also (Win+shift+S)?
    But all that logfile says, is that you don't have proper config there to connect to DB. It tries to connect without any password, so I assume your config file was maybe overwritten by update? Fix the config and it will work again.
    • zoran
      zoran commented
      Which log file I need to check and to edit.
    Logfile that you have on that screenshot... but config file is probably /etc/zabbix/zabbix_server.conf
