Zabbix 6.2.3 PGSQL DB error
  • dissmissed
    • Mar 2021
    • 11
    hi everyone, i apoligies for my bad english..
    we create a new zabbix server and follow logs ;
    [select i.itemid,a.name from applications a,items_applications i where a.applicationid=i.applicationid and i.itemid=23274]
    265:20221202:081655.092 [Z3005] query failed: [0] PGRES_FATAL_ERROR:ERROR: relation "applications" does not exist
    LINE 1: select i.itemid,a.name from applications a,items_application...
    when i compare zabbix server v5 web ui it's seen there Click image for larger version
    and in zabbix 6.2.3 not there Click image for larger version
    how to fix this error?​
    yes.. Applications were converted to tags.
    I suppose that is a frontend query... are you trying to use v5 frontend with v6 DB? Otherwise I would not see any case to have such query...
    • dissmissed
      • Mar 2021
      • 11
      hi.. no,there are we installed the zabbix server 6.2.3postgresql and 6.2.3 proxy postgresql
        Running frontend on same host? Also installed zabbix-web-pgsql package?
        • dissmissed
          • Mar 2021
          • 11
          Hello, yes the infrastructure build with docker and the packages like in the following line;
          timescaledb-pg13:2.7.2
          zabbix-server-pgsql:ubuntu-6.2.3
          zabbix-web-apache-pgsql:6.2.3​
          Here is a full log line;
          [select i.itemid,a.name from applications a,items_applications i where a.applicationid=i.applicationid and i.itemid=50999]
          266:20221206:121600.638 [Z3005] query failed: [0] PGRES_FATAL_ERROR:ERROR: relation "applications" does not exist
          It's a fresh installation and we know in zabbix 6 there is no more applications.
          This log occurs a few times in just a one second. So disks are quickly getting bigger..
          Need your help​
