Logrt and logrt.count of errors repeat past errors
  • Cloud8x4
    • Dec 2013
    • 24
    My log files are rotating per day. the file names are always like `logfile-2022-12-02.log`. Only the date part differs.
    I am trying to use logrt to show errors from a log file only once since the previous measure time.
    Same for logrt.count, I am trying to count the number of errors which happened since the last measure time.
    Item type is `Zabbix agent (active).
    Key is `logrt[/var/logs/logfile*,ERROR,,,skip]`.
    It seems to work fine. I see
    Click image for larger version  Name:	image.png Views:	0 Size:	2.7 KB ID:	455389​​
    Then when another error happens, I see the new error but also the old error.
    ​Click image for larger version  Name:	image.png Views:	0 Size:	2.6 KB ID:	455390​
    When the 3d error happens, I see the same 2 lines + the new error, etc.
    What I expected was to see each line only once.
    What actually happens is that on every file change, all error message are sent again, which results in a lot of duplicate messages.
    Can anyone explain this behaviour?
    For logrt.count it is similar.
    Key is `logrt.count[/var/logs/logfile*,ERROR,,,skip]`
    I see the following.
    Click image for larger version  Name:	image.png Views:	0 Size:	173.6 KB ID:	455387
    According to the graph, At 06:00 there are 8 new errors. At 07:00 there are 8 new errors; at 07:30 again 8 new errors etc.
    What actually happened, is that during the night, there were 8 errors, but at the times where the peaks are visible in the graph, simply some `debug` line was written in the log so the file changed.
    Apparently each time anything is written to the log file, `DEBUG` info in this case, the the Zabbix item sends the complete count of `error` occurences in the whole file.
    When no the file does not change, then it sends `0`.
    What I expected would be that Zabbix sends how many errors happened between each measure time.
    Meaning if the update interval is 1 minute, then I would expect to receive the number of `error` occurences of the past minute; not the accumulation of errors today.
    Thanks a lot.
    You should observe that logfile. Maybe it gets recreated each time something is written there? When its inode changes, its read all over again from beginning.. There is definitely something that forces re-read from beginning...
    • Hamardaban
      • May 2019
      • 2714
      What's your server version and agent version?
      • Cloud8x4
        • Dec 2013
        • 24
        I use 2 docker containers:
        - zabbix/zabbix-server-mysql:alpine-5.0-latest
        - zabbix/zabbix-web-nginx-mysql:alpine-5.0-latest
        The agent on the server has version `5.0.12`.
        Planning an upgrade to the next major version next month,
        • Cloud8x4
          • Dec 2013
          • 24
          Issue solved!
          A couple of months ago I upgraded my Zabbix server container from 5.0 to 6.0 .
          This week I had to add new monitoring on logs.
          Seems log records are not repeating anymore.
