zabbix50 conflicts with zabbix40-4.0.39-1.el7.x86_64
  • FBA420
    • Dec 2022
    Hi, Guys Thanks in advance for your help.
    I am stuck in installing Zabbix to my centos 7. I tried many times so it shows conflict.
    ​ Here are the updates:
    I checked all the packages by
    yum search zabbix* take a look at image 1.
    did clean by yum clean all and after that, I tried to remove them by yum remove Zabbix but it shows there is no package installed.
    try to delete Zabbix-release by rpm -e Zabbix-release but didn't find anything.
    I want 6.2 but Zabbix 50 and 4 conflict with them and also didn't be deleted. One more thing did anyone let me know where the zabbix.arch files placed.​
  • Atsushi
    • Aug 2013
    • 2028
    Since you are not using Zabbix official packages, you will need to remove packages with names starting with the string zabbix40. Please make a backup of the configuration file before removing the packages.
    Also, I don't think Zabbix 6.2 can be installed on CentOS 7. If you want to use a newer version of Zabbix 6.2 or later, I recommend migrating to a newer OS.​
