Update interval - auto discovery
  • RazZ
    • Dec 2022
    I scanned the device automatically to recover all the items. Now I extracted some graphs and realize the interval is 3 minutes. I would like to shorten this but it's greyed out in "host configuration" > "host" > "item".
    Is there anyway to change this ? Is it due to the autodiscovery ?
    Thanks in advance.
  • Atsushi
    • Aug 2013
    • 2028
    If the item was generated using LLD, check the Item prototypes setting in the Discovery rules.
    • RazZ
      • Dec 2022
      Hi Hi Atsushi,
      Thanks a lot, that did it !
      Following up on this, do you recommend a minimum value not to cross ? I'd like to use 15 seconds but I am not sure about the impact on the network. I know there is a lot of parameters to take in account but from a general point of you. Does SNMP generate a lot of traffic ?
