Expression macro in email showing *unknown*
  • Sakoor
    • Nov 2022
    I would like to display some data such as uptime, CPU usage , etc in email alert when there is a problem . I am using expression macro {?last\host\key}, but all being shown as *unknown* in the mail alert. I am using version 6.2.3. Any idea on this. Thanks
  • Markku
    • Sep 2018
    • 1784
    See the documentation for the correct syntax: https://www.zabbix.com/documentation...ression_macros
    Markku
    • Sakoor
      • Nov 2022
      Hi Markku,,
      Thanks for your reply.
      I forgot to mention that it was working well in 6.2.0.
      I'm getting this issue when upgrading to 6.2.3. For example here is the expression I'm using for uptime:
      {? last (/{HOST.HOST}/system.uptime)} ​​
      ​​I tried also​ {?last (//system.uptime)} with no luck
      • Markku
        • Sep 2018
        • 1784
        If I remember correctly, there was some issue in the expression macros lately (but I don't have first-hand experience). See Zabbix release notes and support.zabbix.com for details if needed.
        Note that you are not using the latest version.
        Markku
        • Sakoor
          • Nov 2022
          I just upgraded to 6.2.5 but issue still persisting.
          • Markku
            • Sep 2018
            • 1784
            Remove the extra spaces in your expressions, try 6.2.6 and then open a support case if you can detail your information there.
            Markku
            • Sakoor
              • Nov 2022
              In my expression, I verify there is no space. I also upgraded to 6.2.6 but issue still not resolved.
              Could you perhaps share the link where I can raise a support case. Thanks.
              • Markku
                • Sep 2018
                • 1784
