Which python API module?
  • LenR
    • Sep 2009
    • 1010
    I have used the lukecyca pyzabbix package for years, but just hit a possible bug, I happened to see on the Zabbix integrations page that their recommended package is the abubkov/py-zabbix. I wonder why that one is recommended, the lukecyca seems more popular.
  • Markku
    • Sep 2018
    • 1784
    Please tell more about the possible bug.
    There is even discussion in GitHub issue that the packages are maybe merging: https://github.com/lukecyca/pyzabbix/issues/164
    pyzabbix does not have a sender, maybe that's why Zabbix is "recommending" py-zabbix. (Yes, I hate that py-zabbix managed to select the same pyzabbix namespace...)
    (And yes I'm using pyzabbix in my current projects)
    Markku
    • LenR
      • Sep 2009
      • 1010
      I just opened an issue on the lukecyca project. I'm trying to httptest.create with a longer name than I'd ever had before. This name is 68 characters long and I got error
      HTML Code:
      pyzabbix.api.ZabbixAPIException: ('Error -32602: Invalid params., Invalid parameter "/1/name": value is too long.', -32602)
      I can create the web test via the Zabbix frontend, so it looks like a limit in the module, not Zabbix.
      • Markku
        • Sep 2018
        • 1784
        Ok, let's discuss that in the issue, please submit an example there.
        Markku
        • LenR
          • Sep 2009
          • 1010
          z_url sanitized =
          http://xxx-yyy-main.zzzz.zzzzzzzz.zzz/installation/default-en-US.htm
          API call: minimally sanitized, no guarantee on the indention here, this worked with shorter url's.
          web_resp = zapi.httptest.create(
              "name": z_url,
              "hostid": hostId,
              "delay": "240",
              "verify_host": "1",
              "verify_peer": "1",
              "steps": [
                      "name": "s1",
                      "url": z_url,
                      "status_codes": "200",
                      "no": "1",
              "tags": [
                  {"tag": "Some Tag1", "value": "urlpath"},
                  {"tag": "Application", "value": "Local Preciousness"},
          • Markku
            • Sep 2018
            • 1784
            Have you tried
            a) creating the "long" test in curl? That would mean that API is working but pyzabbix is not
            b) creating the "long" test in GUI, reading it with pyzabbix, deleting in GUI, and recreating the test with the saved data in pyzabbix? (That would ensure that your input data is otherwise correct for the case)
            Markku
            • Markku
              Markku commented
              For the case b), I think I have encountered some case where the error message from Zabbix was not actually correct, that's why I think it is useful to check the request data otherwise as well.
              Markku
          • Markku
            • Sep 2018
            • 1784
            Btw what Zabbix version is this?
            Markku
            • LenR
              • Sep 2009
              • 1010
              Zabbix is 6.0, I've not done the more difficult testing, it's been a LONG TIME since I tested with curl. I'll get to it eventually, but today is my Friday.
              • Markku
                • Sep 2018
                • 1784
                Fair enough. As a general comment, pyzabbix is not mangling the data much, and there are no practical string limits in Python, so my assumption based on the case description is that the problem is in Zabbix API, not pyzabbix. But let's see later.
                Markku
                • LenR
                  • Sep 2009
                  • 1010
                  I agree, I did try in py-zabbix and it gets the same issue.
                  I have support, I'll open a case :-)
                  • Markku
                    • Sep 2018
                    • 1784
                    My Zabbix 6.2.4 testhost truncates the web scenario name at 64 characters in GUI.
                    Markku
                    • LenR
                      • Sep 2009
                      • 1010
                      Oh, I hadn't noticed that, it worked but I didn't see the shorter name. I'm not sure if that is better or worse.
                      There is nothing to protect me form a use asking for 2 urls that have the same first 64 characters. Users are the root cause here...
                      • Markku
                        • Sep 2018
                        • 1784
                        But it's just the name, right? Not the URL
                        Markku
                        • LenR
                          • Sep 2009
                          • 1010
                          Right, but I was trying to use the url for the name, otherwise I'll have to invent a name.
                          • Markku
                            • Sep 2018
                            • 1784
                            #15
                            Two hardest problems in IT:
                            1. Users
                            2. Naming things
                            3. Off-by-one errors
                            Markku
