Implementing Dell Switch MIBs?
  • admin@psmnv.com
    • May 2022
    • 41
    Greetings!
    We have Dell S5248F-ON switches. We downloaded the MIBs from Dell, but they came as a set of different files (see below). We only need to monitor the basics, like interface statistics (xfer bytes/sec, rcv bytes/sec, and other ethernet-related stats, bridge forwarding database, etc.), plus simple chassis and OS info like model, OS version, memory and CPU utilization, temperature, and power supplies). We don't need all the other stuff in all those MIBs.
    We used Sean Bradley's SNMP2ZABBIX​ script to convert a couple of MIBs to XML and successfully imported them, but we can only apply one MIB to a switch. For example, we can apply the CHASSIS mib fine, but it does not monitor any interfaces. If we then try to import the Etherlike-MIB or the IF-MIB, we get an error that OIDs already exist. Can anyone tell us which MIB files we need, which ones are dependent on others, and how to import multiple ones?
    Any SNMP experts would be greatly appreciated!
    BRIDGE-MIB.mib
    DELLEMC-OS10-BGP4V2-MIB.mib
    DELLEMC-OS10-CHASSIS-MIB.mib
    DELLEMC-OS10-PRODUCTS-MIB.mib
    DELLEMC-OS10-SMI-MIB.mib
    DELLEMC-OS10-TC-MIB.mib
    ENTITY-MIB.mib
    EtherLike-MIB.mib
    HOST-RESOURCES-MIB.mib
    IANA-ADDRESS-FAMILY-NUMBERS-MIB.mib
    IANA-ENTITY-MIB.mib
    IANA-RTPROTO-MIB.mib
    IANAifType-MIB.mib
    IEEE8021-PFC-MIB.mib
    IEEE8023-LAG-MIB.mib
    IF-MIB.mib
    INET-ADDRESS-MIB.mib
    IP-FORWARD-MIB.mib
    IP-MIB.mib
    LLDP-EXT-DOT1-MIB.mib
    LLDP-EXT-DOT3-MIB.mib
    LLDP-MIB.mib
    OSPF-MIB.mib
    OSPFV3-MIB.mib
    P-BRIDGE-MIB.mib
    Q-BRIDGE-MIB.mib
    RFC-1212.mib
    RFC1155-SMI.mib
    RFC1213-MIB.mib
    RFC1271-MIB.mib
    RMON-MIB.mib
    RMON2-MIB.mib
    SFLOW-MIB.mib
    SNMP-FRAMEWORK-MIB.mib
    SNMP-MPD-MIB.mib
    SNMP-TARGET-MIB.mib
    SNMP-USER-BASED-SM-MIB.mib
    SNMP-VIEW-BASED-ACM-MIB.mib
    SNMPv2-CONF.mib
    SNMPv2-MIB.mib
    SNMPv2-SMI.mib
    SNMPv2-TC.mib
    TCP-MIB.mib
    TOKEN-RING-RMON-MIB.mib
    UDP-MIB.mib
    UUID-TC-MIB.mib
  • Hamardaban
    • May 2019
    • 2714
    For monitoring via snmp mib files are optional.
    You can create your template with only the metrics you need.
    To do this, you will need OIDs of metrics that you can get from MIB or snmpwalk or other sources.
