net-snmp > zabbix_traps.tmp fails extracting with some traps.
  • jesras
    • Dec 2022
    HI,
    I am new here - hope for an idea to fix a problem I have extracting snmptraps to zabbix.
    Been using snmp trap receiver works great, but discovered that a few snmptraps are not extracted to the /tmp/zabbix_traps.tmp, I use the standars perl script and it works well.
    My problem is that Traps send with DNS nane and not IP address seems not to be extracted to zabbix:traps.tmp all using IP does.
    ex snmp trap:
    NOT EXTRATCED : 11:00:03.326229 IP hidenat.xxxx.dk.3470 > zabbix.internal.cloudapp.net.snmp-trap:
    EXTRACTED OK : 10:55:00.043042 IP 51.144.xx.xxx.41756 > zabbix.internal.cloudapp.net.snmp-trap:
    Any ideas where to look and maybe why DNS is not working?
    Thanks​
  • Markku
    • Sep 2018
    • 1784
    See the documentation about SNMP traps: https://www.zabbix.com/documentation...types/snmptrap
    5. For each trap Zabbix finds all "SNMP trapper" items with host interfaces matching the received trap address. Note that only the selected "IP" or "DNS" in host interface is used during the matching.
    So if you don't have a host called "hidenat.xxxx.dk" in Zabbix it won't match any host.
    Markku
    • jesras
      jesras commented
      I have setup a host with snmp interface called hidenat.xxxx.dk so thats not the case.
  • jesras
    • Dec 2022
    Host interface:
    • Markku
      • Sep 2018
      • 1784
      Can you clarify "not extracted to zabbix_traps.tmp", do you mean that the trap was not saved there?
      Is the SNMP trap community correctly configured?
      Markku
      • jesras
        jesras commented
        The community is setup like other already working traps, difference is that they used ip not DNS for identification.
        I see the traps arriving with tcpdump port 162 together with other traps, traps using ip is written to zabbix_traps.tmp but not the once using DNS.
        The script used for this is all standard. (no modifications made)
    • Markku
      • Sep 2018
      • 1784
      By looking at the script at https://git.zabbix.com/projects/ZBX/...ap_receiver.pl there are no selection statements: whatever comes in should also come out (to the file), but you are saying that some traps are saved but others are not.
      So you need to troubleshoot why your snmptrapd does not call the script in some cases. Or is your trap receiver script somehow faulty? (You haven't mentioned where the script has come from)
      How is your snmptrapd configured? For the reference, here is one example: https://majornetwork.net/2021/05/con...bix-on-debian/
      To be clear: this is not a Zabbix problem based on your problem description, this is an snmptrapd problem. I'm not sure what you mean "DNS for identification".
      Markku
      • Markku
        • Sep 2018
        • 1784
        Btw based on https://linux.die.net/man/8/snmptrapd there is -n option in snmptrapd to disable reverse name lookups if that helps you.
        Markku
