Filesystem monitoring
  • dsipe
    • Oct 2006
    • 184
    Hye,
    I tried to monitoring %free space on a Linux filesystem and a Windows C: drive.
    I create the following items :
    vfs.fs.size[/home,pfree] for Linux
    vfs.fs.size[c:,pfree] for windows
    Both of them are flagged "not supported".
    Any ideas ?
    If that's not correct, what's the right approach to monitor free disk space in percentage under Windows & Linux ?
    Thanks 2 all
    Pascal
  • tapto
    • Nov 2006
    • 28
    Just a thought
    are you using float ?
    integer will create this error
    • dsipe
      • Oct 2006
      • 184
      thanks a lot for y answer.
      it's ok now on AIX box with the float type.
      but it always go wrong on the windows one....
      • RandySpinaGE
        • Jun 2006
        • 57
        Prompt# /usr/local/bin/zabbix_get -s X.Y.Z.Linuxnode -k vfs.fs.size[/,free]
        9036800
        Prompt# /usr/local/bin/zabbix_get -s X.Y.Z.Windownode -k vfs.fs.size[c:,free]
        23039279104.000000
        Prompt# /usr/local/bin/zabbix_get -s X.Y.Z.Linuxnode -k vfs.fs.size[/,pfree]
        74.714941
        Prompt# /usr/local/bin/zabbix_get -s X.Y.Z.Windownode -k vfs.fs.size[c:,pfree]
        ZBX_NOTSUPPORTED
        Looks to me like Percent free is not supported by ZabbixW32.exe
        Zabbix Win32 Agent Version 1.1 Build of Jun 5 2006
        zabbix server = 1.1.3
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          Upgrade your Windows agent to 1.1.3 to make it work.
          Alexei Vladishev
          New York | Tokyo | Riga
          My Twitter
          • LEM
            • Sep 2004
            • 112
            You should use a Win32 agent more recent (see http://www.zabbix.com/forum/showthre...ighlight=pfree )
            For example NSIS install packages from Scotty
            Cheers,
            lem
            LEM
            • dsipe
              • Oct 2006
              • 184
              ok, thanks to all for your answers.
              it's ok now.
              instead of using the windows binaries included in the tar.gz, i use the one on the download page [ windows binaries 1.1 ], believing that there were the most up-to-date.
              thanks again.
              • luketrot
                • Nov 2006
                • 14
                I'm not having any luck using pfree on 1.1.4 server and client on XP. When creating an item Zabbix agent, vfs.fs.size[c:,pfree], Num Float, my results are 0 however on the server doing the following:
                -su-2.05b# zabbix_get -s dino -k vfs.fs.size[c:,pfree]
                83.892256
                So it works on the server...
                • dantheman
                  • May 2006
                  • 209
                  If you look at the item definition, is there a custom multiplier set? If so, it's not at 0 is it?
                  • luketrot
                    • Nov 2006
                    • 14
                    The multiplier is disabled, I tried enabling it and adding 1 without any luck as well. I'm completely stumped.
                    • subba5678
                      • May 2010
                      • 132
                      Hi All,
                      I want to monitor the windows server and would like to create a trigger if the disk space reached to 98.5% . I am unable to create a trigger for the percentage . Please help me out . As I am using the windows zabbix agent version 1.8.2 and server 1.8.1
                      Thanks,
                      Subbu
