Audit log questions after 5.0 to 6.0 upgrade
  • LenR
    • Sep 2009
    • 1011
    From the audit report, say for a trigger that was enabled, how do I find the trigger? I though it was click on Id, but that just further filters the report.
    I also updated a tag on a trigger and can't find anything in the audit for that change, would a trigger tag name change be logged?
  • Markku
    • Sep 2018
    • 1784
    It looks like the audit log has been implemented as a minimal feature to tick the box for "Audit logging in Zabbix: yes there is". And rightly so from my point of view, I've never actually used it
    The only way to open the trigger by ID I know of (in the GUI) is to open a trigger for any host, and then replace the ID in the URL with the ID you are looking for.
    https://zabbixtest.example.com/zabbix/triggers.php?form=update&triggerid=22971&context=host
    Seems to work here at least.
    I would expect it to be logged, but I don't see that happening. You could open an enhancement request on https://support.zabbix.com if you feel like it.
    Markku
