How to set Trigger to send alert after 15 mins?
  • NewUser1
    • Oct 2022
    • 36
    I have two triggers set for when the cpu reaches 80% and 90% they work fine but I want to make it that they send an alert after the cpu has remained above 80% or 90% for 15 minutes.
    Here is the expression I got for 80%
    min(/Windows by Zabbix agent/system.cpu.util[all,system,avg5],15m)>80
    Here it is for 90%
    min(/Windows by Zabbix agent/system.cpu.util,15m)>90
    Where am I making a mistake with my expressions?
    Mistakes?
    2 different items? "system.cpu.util[all,system,avg5]" and "system.cpu.util" ?
    Other thing is .. that first trigger should consider values between 80 and 90 and other one values over 90... so your first one should be "min(item,15m)>80 and max(item,15m)<90" and the other one just "min(item,15m)>90"
    • NewUser1
      • Oct 2022
      • 36
      Originally posted by cyber
      Mistakes?
      What I meant is that one of my triggers is for when the cpu hits 80% and my second trigger is for when the cpu hits 90%. What I want is for both triggers to trigger only after they have remained at their respective percentages after 15minutes or longer.
      So I assume that the expression for 80% should look like this "min(/Windows by Zabbix agent/system.cpu.util[all,system,avg5],15m)>80"
      and for 90% should look like this "min(/Windows by Zabbix agent/system.cpu.util,15m)>90"
      if you are wondering why I didn't use "system.cpu.util" for the 80% expression it was because it was being used for the 90% expression that was prebuilt already. I had to make this expression for the 80% "system.cpu.util[all,system,avg5],15m)>80"
        Looks fine to me.."min (/host/key,(sec|#num)<:time shift>)​"
        Do you have any suspicions, that it does not work?
        You can use same item in multiple triggers...
