After Upgrading to 6.0.12 from 6.0.5 zabbix-server does not start
  • fatih.kalemci
    • Dec 2022
    I was using zabbix with mysql and elasticsearch (mysql version:8.0.23 elasticsearh version:7.10.0)
    before update;
    zabbix-server-mysql:
    Installed: 1:6.0.5-1+ubuntu20.04
    zabbix-frontend-php:
    zabbix-nginx-conf:
    Installed: 1:6.0.3-1+ubuntu20.04
    zabbix-sql-scripts:
    zabbix-agent:
    I updated all of the above to 6.0.12 then zabbix-server couldn't start. with the following log:
    Starting Zabbix Server. Zabbix 6.0.12 (revision 126aa2f53e9).
    ****** Enabled features ******
    SNMP monitoring:           YES
    IPMI monitoring:           YES
    Web monitoring:            YES
    VMware monitoring:         YES
    SMTP authentication:       YES
    ODBC:                      YES
    SSH support:               YES
    IPv6 support:              YES
    TLS support:               YES
    using configuration file: /etc/zabbix/zabbix_server.conf
    In zbx_load_modules()
    End of zbx_load_modules():SUCCEED
    In zbx_ipc_service_start() service:rtc
    In zbx_ipc_socket_open()
    End of zbx_ipc_socket_open():FAIL
    End of zbx_ipc_service_start():SUCCEED
    In zbx_db_get_database_type()
    In DBconnect() flag:0
    End of DBconnect():0
    query [txnlev:0] [select userid from users limit 1]
    there is at least 1 record in "users" table
    End of zbx_db_get_database_type():ZBX_DB_SERVER
    In init_database_cache()
    In zbx_mem_create() param:'HistoryCacheSize' size:536870912
    valid user addresses: [0x7f0bdf3b7170, 0x7f0bff3b6ff0] total size: 536870528
    End of zbx_mem_create()
    In zbx_mem_create() param:'HistoryIndexCacheSize' size:209715200
    valid user addresses: [0x7f0bd2bb7180, 0x7f0bdf3b6ff0] total size: 209714800
    In init_trend_cache()
    In zbx_mem_required_size() size:0 chunks_num:1 descr:'trend cache' param:'TrendCacheSize'
    End of zbx_mem_required_size() size:422
    In zbx_mem_create() param:'TrendCacheSize' size:33554432
    valid user addresses: [0x7f0bd0bb7170, 0x7f0bd2bb6ff0] total size: 33554048
    End of init_trend_cache()
    End of init_database_cache()
    query [txnlev:0] [select default_character_set_name,default_collation_name from information_schema.SCHEMATA where schema_name='zabbix']
    query [txnlev:0] [select count(*) from information_schema.`COLUMNS` where table_schema='zabbix' and data_type in ('text','varchar','longtext') and (character_set_name not in ('utf8','utf8mb3','utf8mb4') or collation_name not in ('utf8_bin','utf8mb3_bin','utf8mb4_bin'))]
    In zbx_dbms_version_info_extract()
    End of zbx_dbms_version_info_extract() version:80023
    In DBcheck_version()
    query [txnlev:0] [show tables like 'dbversion']
    query [txnlev:0] [select mandatory,optional from dbversion]
    current database version (mandatory/optional): 06000000/06000017
    required mandatory version: 06000000
    End of DBcheck_version():SUCCEED
    query [txnlev:0] [show columns from config like 'dbversion_status']
    query [txnlev:0] [show index from history where key_name='PRIMARY']
    In zbx_elastic_version_extract()
    ElasticDB version retrieved unparsed: 7.10.0
    Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x15]. Crashing ...
    ====== Fatal information: ======
    Program counter: 0x55c0588c3a52
    === Registers: ===
    r8      =                0 =                    0 =                    0
    r9      =     7ffcb83837c0 =      140723399178176 =      140723399178176
    r10     =     55c0589fc52f =       94284608947503 =       94284608947503
    r11     =     7ffcb8383677 =      140723399177847 =      140723399177847
    r12     =     55c058669b00 =       94284605201152 =       94284605201152
    r13     =     7ffcb8385e30 =      140723399188016 =      140723399188016
    r14     =                0 =                    0 =                    0
    r15     =                0 =                    0 =                    0
    rdi     =               15 =                   21 =                   21
    rsi     =                1 =                    1 =                    1
    rbp     =     7ffcb8383990 =      140723399178640 =      140723399178640
    rbx     =     55c0589abc00 =       94284608617472 =       94284608617472
    rdx     =                1 =                    1 =                    1
    rax     =               15 =                   21 =                   21
    rcx     =                1 =                    1 =                    1
    rsp     =     7ffcb8383960 =      140723399178592 =      140723399178592
    rip     =     55c0588c3a52 =       94284607666770 =       94284607666770
    efl     =            10202 =                66050 =                66050
    csgsfs  =   2b000000000033 =    12103423998558259 =    12103423998558259
    err     =                4 =                    4 =                    4
    trapno  =                e =                   14 =                   14
    oldmask =                0 =                    0 =                    0
    cr2     =               15 =                   21 =                   21
    === Backtrace: ===
    14: /usr/sbin/zabbix_server(zbx_backtrace+0x52) [0x55c05887c1ef]
    13: /usr/sbin/zabbix_server(zbx_log_fatal_info+0x183) [0x55c05887c4e8]
    12: /usr/sbin/zabbix_server(+0x27be9a) [0x55c05887ce9a]
    11: /lib/x86_64-linux-gnu/libpthread.so.0(+0x143c0) [0x7f0c038ad3c0]
    10: /usr/sbin/zabbix_server(+0x2c2a52) [0x55c0588c3a52]
    9: /usr/sbin/zabbix_server(zbx_json_addstring+0x8f) [0x55c0588c40f0]
    8: /usr/sbin/zabbix_server(zbx_db_version_json_create+0x164) [0x55c05898aa13]
    7: /usr/sbin/zabbix_server(zbx_elastic_version_extract+0x7f8) [0x55c058873ff2]
    6: /usr/sbin/zabbix_server(zbx_history_check_version+0x33) [0x55c058870a7d]
    5: /usr/sbin/zabbix_server(+0x6a0c8) [0x55c05866b0c8]
    4: /usr/sbin/zabbix_server(MAIN_ZABBIX_ENTRY+0x5c2) [0x55c05866c7ff]
    3: /usr/sbin/zabbix_server(daemon_start+0x3ca) [0x55c05887bd12]
    2: /usr/sbin/zabbix_server(main+0x34d) [0x55c05866aec2]
    1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3) [0x7f0c028c50b3]
    0: /usr/sbin/zabbix_server(_start+0x2e) [0x55c058669b2e]
    === Memory map: ===
    55c058601000-55c058666000 r--p 00000000 09:03 6423039                    /usr/sbin/zabbix_server
    55c058666000-55c0589ac000 r-xp 00065000 09:03 6423039                    /usr/sbin/zabbix_server
    55c0589ac000-55c058ace000 r--p 003ab000 09:03 6423039                    /usr/sbin/zabbix_server
    55c058acf000-55c058b98000 r--p 004cd000 09:03 6423039                    /usr/sbin/zabbix_server
    55c058b98000-55c058ba8000 rw-p 00596000 09:03 6423039                    /usr/sbin/zabbix_server
    55c058ba8000-55c058bb7000 rw-p 00000000 00:00 0
    55c059a4d000-55c059a9b000 rw-p 00000000 00:00 0                          [heap]
    55c059a9b000-55c059b03000 rw-p 00000000 00:00 0                          [heap]
    7f0bd0bb7000-7f0bd2bb7000 rw-s 00000000 00:01 131077                     /SYSV00000000 (deleted)
    7f0bd2bb7000-7f0bdf3b7000 rw-s 00000000 00:01 131076                     /SYSV00000000 (deleted)
    7f0bdf3b7000-7f0bff3b7000 rw-s 00000000 00:01 131075                     /SYSV00000000 (deleted)
    7f0bff3b7000-7f0bffda4000 r--s 00000000 09:02 11011305                   /var/lib/sss/mc/initgroups
    7f0bffda4000-7f0bffda6000 r--p 00000000 09:03 6435378                    /usr/lib/x86_64-linux-gnu/libnss_sss.so.2
    7f0bffda6000-7f0bffdac000 r-xp 00002000 09:03 6435378                    /usr/lib/x86_64-linux-gnu/libnss_sss.so.2
    7f0bffdac000-7f0bffdae000 r--p 00008000 09:03 6435378                    /usr/lib/x86_64-linux-gnu/libnss_sss.so.2
    7f0bffdae000-7f0bffdaf000 r--p 00009000 09:03 6435378                    /usr/lib/x86_64-linux-gnu/libnss_sss.so.2
    7f0bffdaf000-7f0bffdb0000 rw-p 0000a000 09:03 6435378                    /usr/lib/x86_64-linux-gnu/libnss_sss.so.2
    7f0bffdb0000-7f0bffdb6000 r--p 00000000 09:03 6422612                    /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    7f0bffdb6000-7f0bffddc000 r-xp 00006000 09:03 6422612                    /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    7f0bffddc000-7f0bffde8000 r--p 0002c000 09:03 6422612                    /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    7f0bffde8000-7f0bffdeb000 r--p 00037000 09:03 6422612                    /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    7f0bffdeb000-7f0bffdec000 rw-p 0003a000 09:03 6422612                    /usr/lib/x86_64-linux-gnu/libnss_systemd.so.2
    7f0bffdec000-7f0bffdef000 r--p 00000000 09:03 6433430                    /usr/lib/x86_64-linux-gnu/libnss_files-2.31.so
    7f0bffdef000-7f0bffdf6000 r-xp 00003000 09:03 6433430                    /usr/lib/x86_64-linux-gnu/libnss_files-2.31.so
    7f0bffdf6000-7f0bffdf8000 r--p 0000a000 09:03 6433430                    /usr/lib/x86_64-linux-gnu/libnss_files-2.31.so
    7f0bffdf8000-7f0bffdf9000 r--p 0000b000 09:03 6433430                    /usr/lib/x86_64-linux-gnu/libnss_files-2.31.so
    7f0bffdf9000-7f0bffdfa000 rw-p 0000c000 09:03 6433430                    /usr/lib/x86_64-linux-gnu/libnss_files-2.31.so
    7f0bffdfa000-7f0bffe09000 rw-p 00000000 00:00 0
    7f0bffe09000-7f0bffe0b000 r--p 00000000 09:03 6425485                    /usr/lib/x86_64-linux-gnu/libffi.so.7.1.0
    7f0bffe0b000-7f0bffe11000 r-xp 00002000 09:03 6425485                    /usr/lib/x86_64-linux-gnu/libffi.so.7.1.0
    7f0bffe11000-7f0bffe12000 r--p 00008000 09:03 6425485                    /usr/lib/x86_64-linux-gnu/libffi.so.7.1.0
    7f0bffe12000-7f0bffe13000 ---p 00009000 09:03 6425485                    /usr/lib/x86_64-linux-gnu/libffi.so.7.1.0
    7f0bffe13000-7f0bffe14000 r--p 00009000 09:03 6425485                    /usr/lib/x86_64-linux-gnu/libffi.so.7.1.0
    7f0bffe14000-7f0bffe15000 rw-p 0000a000 09:03 6425485                    /usr/lib/x86_64-linux-gnu/libffi.so.7.1.0
    7f0bffe15000-7f0bffe17000 r--p 00000000 09:03 6425454                    /usr/lib/x86_64-linux-gnu/libcrypt.so.1.1.0
    7f0bffe17000-7f0bffe2c000 r-xp 00002000 09:03 6425454                    /usr/lib/x86_64-linux-gnu/libcrypt.so.1.1.0
    7f0bffe2c000-7f0bffe46000 r--p 00017000 09:03 6425454                    /usr/lib/x86_64-linux-gnu/libcrypt.so.1.1.0
    7f0bffe46000-7f0bffe47000 r--p 00030000 09:03 6425454                    /usr/lib/x86_64-linux-gnu/libcrypt.so.1.1.0
    7f0bffe47000-7f0bffe48000 rw-p 00031000 09:03 6425454                    /usr/lib/x86_64-linux-gnu/libcrypt.so.1.1.0
    7f0bffe48000-7f0bffe50000 rw-p 00000000 00:00 0
    7f0bffe50000-7f0bffe5e000 r--p 00000000 09:03 6424657                    /usr/lib/x86_64-linux-gnu/libsqlite3.so.0.8.6
    7f0bffe5e000-7f0bfff3e000 r-xp 0000e000 09:03 6424657                    /usr/lib/x86_64-linux-gnu/libsqlite3.so.0.8.6
    7f0bfff3e000-7f0bfff72000 r--p 000ee000 09:03 6424657                    /usr/lib/x86_64-linux-gnu/libsqlite3.so.0.8.6
    7f0bfff72000-7f0bfff73000 ---p 00122000 09:03 6424657                    /usr/lib/x86_64-linux-gnu/libsqlite3.so.0.8.6
    7f0bfff73000-7f0bfff76000 r--p 00122000 09:03 6424657                    /usr/lib/x86_64-linux-gnu/libsqlite3.so.0.8.6
    7f0bfff76000-7f0bfff79000 rw-p 00125000 09:03 6424657                    /usr/lib/x86_64-linux-gnu/libsqlite3.so.0.8.6
    7f0bfff79000-7f0bfff7b000 rw-p 00000000 00:00 0
    7f0bfff7b000-7f0bfff8b000 r--p 00000000 09:03 6431136                    /usr/lib/x86_64-linux-gnu/libhx509.so.5.0.0
    7f0bfff8b000-7f0bfffb4000 r-xp 00010000 09:03 6431136                    /usr/lib/x86_64-linux-gnu/libhx509.so.5.0.0
    7f0bfffb4000-7f0bfffc4000 r--p 00039000 09:03 6431136                    /usr/lib/x86_64-linux-gnu/libhx509.so.5.0.0
    7f0bfffc4000-7f0bfffc7000 r--p 00048000 09:03 6431136                    /usr/lib/x86_64-linux-gnu/libhx509.so.5.0.0
    7f0bfffc7000-7f0bfffc8000 rw-p 0004b000 09:03 6431136                    /usr/lib/x86_64-linux-gnu/libhx509.so.5.0.0
    7f0bfffc8000-7f0bfffc9000 rw-p 00000000 00:00 0
    7f0bfffc9000-7f0bfffcc000 r--p 00000000 09:03 6431130                    /usr/lib/x86_64-linux-gnu/libheimbase.so.1.0.0
    7f0bfffcc000-7f0bfffd5000 r-xp 00003000 09:03 6431130                    /usr/lib/x86_64-linux-gnu/libheimbase.so.1.0.0
    7f0bfffd5000-7f0bfffd9000 r--p 0000c000 09:03 6431130                    /usr/lib/x86_64-linux-gnu/libheimbase.so.1.0.0
    7f0bfffd9000-7f0bfffda000 r--p 0000f000 09:03 6431130                    /usr/lib/x86_64-linux-gnu/libheimbase.so.1.0.0
    7f0bfffda000-7f0bfffdb000 rw-p 00010000 09:03 6431130                    /usr/lib/x86_64-linux-gnu/libheimbase.so.1.0.0
    7f0bfffdb000-7f0bfffdc000 r--p 00000000 09:03 6431134                    /usr/lib/x86_64-linux-gnu/libwind.so.0.0.0
    7f0bfffdc000-7f0bfffde000 r-xp 00001000 09:03 6431134                    /usr/lib/x86_64-linux-gnu/libwind.so.0.0.0
    7f0bfffde000-7f0c00003000 r--p 00003000 09:03 6431134                    /usr/lib/x86_64-linux-gnu/libwind.so.0.0.0
    7f0c00003000-7f0c00004000 r--p 00027000 09:03 6431134                    /usr/lib/x86_64-linux-gnu/libwind.so.0.0.0
    7f0c00004000-7f0c00005000 rw-p 00028000 09:03 6431134                    /usr/lib/x86_64-linux-gnu/libwind.so.0.0.0
    7f0c00005000-7f0c00007000 r--p 00000000 09:03 6430746                    /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.8
    7f0c00007000-7f0c00009000 r-xp 00002000 09:03 6430746                    /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.8
    7f0c00009000-7f0c0000a000 r--p 00004000 09:03 6430746                    /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.8
    7f0c0000a000-7f0c0000b000 r--p 00004000 09:03 6430746                    /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.8
    7f0c0000b000-7f0c0000c000 rw-p 00005000 09:03 6430746                    /usr/lib/x86_64-linux-gnu/libkeyutils.so.1.8
    7f0c0000c000-7f0c0000d000 r--p 00000000 09:03 6424845                    /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.7
    7f0c0000d000-7f0c0000e000 r-xp 00001000 09:03 6424845                    /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.7
    7f0c0000e000-7f0c0002d000 r--p 00002000 09:03 6424845                    /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.7
    7f0c0002d000-7f0c0002e000 r--p 00020000 09:03 6424845                    /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.7
    7f0c0002e000-7f0c0002f000 rw-p 00021000 09:03 6424845                    /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1.0.7
    7f0c0002f000-7f0c00031000 rw-p 00000000 00:00 0
    7f0c00031000-7f0c0003b000 r--p 00000000 09:03 6425504                    /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.0
    7f0c0003b000-7f0c0009b000 r-xp 0000a000 09:03 6425504                    /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.0
    7f0c0009b000-7f0c000b2000 r--p 0006a000 09:03 6425504                    /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.0
    7f0c000b2000-7f0c000b3000 ---p 00081000 09:03 6425504                    /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.0
    7f0c000b3000-7f0c000b4000 r--p 00081000 09:03 6425504                    /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.0
    7f0c000b4000-7f0c000b5000 rw-p 00082000 09:03 6425504                    /usr/lib/x86_64-linux-gnu/libgmp.so.10.4.0
    7f0c000b5000-7f0c000bc000 r--p 00000000 09:03 6425565                    /usr/lib/x86_64-linux-gnu/libhogweed.so.5.0
    7f0c000bc000-7f0c000cc000 r-xp 00007000 09:03 6425565                    /usr/lib/x86_64-linux-gnu/libhogweed.so.5.0
    7f0c000cc000-7f0c000ea000 r--p 00017000 09:03 6425565                    /usr/lib/x86_64-linux-gnu/libhogweed.so.5.0
    7f0c000ea000-7f0c000eb000 r--p 00034000 09:03 6425565                    /usr/lib/x86_64-linux-gnu/libhogweed.so.5.0
    7f0c000eb000-7f0c000ec000 rw-p 00035000 09:03 6425565                    /usr/lib/x86_64-linux-gnu/libhogweed.so.5.0
    7f0c000ec000-7f0c000f5000 r--p 00000000 09:03 6425456                    /usr/lib/x86_64-linux-gnu/libnettle.so.7.0
    7f0c000f5000-7f0c00113000 r-xp 00009000 09:03 6425456                    /usr/lib/x86_64-linux-gnu/libnettle.so.7.0
    7f0c00113000-7f0c00123000 r--p 00027000 09:03 6425456                    /usr/lib/x86_64-linux-gnu/libnettle.so.7.0
    7f0c00123000-7f0c00125000 r--p 00036000 09:03 6425456                    /usr/lib/x86_64-linux-gnu/libnettle.so.7.0
    7f0c00125000-7f0c00126000 rw-p 00038000 09:03 6425456                    /usr/lib/x86_64-linux-gnu/libnettle.so.7.0
    7f0c00126000-7f0c00129000 r--p 00000000 09:03 6425636                    /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    7f0c00129000-7f0c00135000 r-xp 00003000 09:03 6425636                    /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    7f0c00135000-7f0c00139000 r--p 0000f000 09:03 6425636                    /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    7f0c00139000-7f0c0013a000 ---p 00013000 09:03 6425636                    /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    7f0c0013a000-7f0c0013b000 r--p 00013000 09:03 6425636                    /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    7f0c0013b000-7f0c0013c000 rw-p 00014000 09:03 6425636                    /usr/lib/x86_64-linux-gnu/libtasn1.so.6.6.0
    7f0c0013c000-7f0c0014c000 r--p 00000000 09:03 6425646                    /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    7f0c0014c000-7f0c00182000 r-xp 00010000 09:03 6425646                    /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    7f0c00182000-7f0c002b9000 r--p 00046000 09:03 6425646                    /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    7f0c002b9000-7f0c002ba000 ---p 0017d000 09:03 6425646                    /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    7f0c002ba000-7f0c002bd000 r--p 0017d000 09:03 6425646                    /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    7f0c002bd000-7f0c002be000 rw-p 00180000 09:03 6425646                    /usr/lib/x86_64-linux-gnu/libunistring.so.2.1.0
    7f0c002be000-7f0c002c0000 rw-p 00000000 00:00 0
    7f0c002c0000-7f0c002eb000 r--p 00000000 09:03 6425515                    /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    7f0c002eb000-7f0c00385000 r-xp 0002b000 09:03 6425515                    /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    7f0c00385000-7f0c003e1000 r--p 000c5000 09:03 6425515                    /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    7f0c003e1000-7f0c003ec000 r--p 00120000 09:03 6425515                    /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    7f0c003ec000-7f0c003f6000 rw-p 0012b000 09:03 6425515                    /usr/lib/x86_64-linux-gnu/libp11-kit.so.0.3.0
    7f0c003f6000-7f0c003fb000 r--p 00000000 09:03 6431126                    /usr/lib/x86_64-linux-gnu/libroken.so.18.1.0
    7f0c003fb000-7f0c00408000 r-xp 00005000 09:03 6431126                    /usr/lib/x86_64-linux-gnu/libroken.so.18.1.0
    7f0c00408000-7f0c0040c000 r--p 00012000 09:03 6431126                    /usr/lib/x86_64-linux-gnu/libroken.so.18.1.0
    7f0c0040c000-7f0c0040d000 ---p 00016000 09:03 6431126                    /usr/lib/x86_64-linux-gnu/libroken.so.18.1.0
    7f0c0040d000-7f0c0040e000 r--p 00016000 09:03 6431126                    /usr/lib/x86_64-linux-gnu/libroken.so.18.1.0
    7f0c0040e000-7f0c0040f000 rw-p 00017000 09:03 6431126                    /usr/lib/x86_64-linux-gnu/libroken.so.18.1.0
    7f0c0040f000-7f0c00416000 r--p 00000000 09:03 6431132                    /usr/lib/x86_64-linux-gnu/libhcrypto.so.4.1.0
    7f0c00416000-7f0c00435000 r-xp 00007000 09:03 6431132                    /usr/lib/x86_64-linux-gnu/libhcrypto.so.4.1.0
    7f0c00435000-7f0c00443000 r--p 00026000 09:03 6431132                    /usr/lib/x86_64-linux-gnu/libhcrypto.so.4.1.0
    7f0c00443000-7f0c00445000 r--p 00033000 09:03 6431132                    /usr/lib/x86_64-linux-gnu/libhcrypto.so.4.1.0
    7f0c00445000-7f0c00446000 rw-p 00035000 09:03 6431132                    /usr/lib/x86_64-linux-gnu/libhcrypto.so.4.1.0
    7f0c00446000-7f0c00447000 rw-p 00000000 00:00 0
    7f0c00447000-7f0c00461000 r--p 00000000 09:03 6431128                    /usr/lib/x86_64-linux-gnu/libasn1.so.8.0.0
    7f0c00461000-7f0c004cc000 r-xp 0001a000 09:03 6431128                    /usr/lib/x86_64-linux-gnu/libasn1.so.8.0.0
    7f0c004cc000-7f0c004e9000 r--p 00085000 09:03 6431128                    /usr/lib/x86_64-linux-gnu/libasn1.so.8.0.0
    7f0c004e9000-7f0c004ea000 ---p 000a2000 09:03 6431128                    /usr/lib/x86_64-linux-gnu/libasn1.so.8.0.0
    7f0c004ea000-7f0c004eb000 r--p 000a2000 09:03 6431128                    /usr/lib/x86_64-linux-gnu/libasn1.so.8.0.0
    7f0c004eb000-7f0c004ee000 rw-p 000a3000 09:03 6431128                    /usr/lib/x86_64-linux-gnu/libasn1.so.8.0.0
    7f0c004ee000-7f0c00509000 r--p 00000000 09:03 6431138                    /usr/lib/x86_64-linux-gnu/libkrb5.so.26.0.0
    7f0c00509000-7f0c0055a000 r-xp 0001b000 09:03 6431138                    /usr/lib/x86_64-linux-gnu/libkrb5.so.26.0.0
    7f0c0055a000-7f0c0057a000 r--p 0006c000 09:03 6431138                    /usr/lib/x86_64-linux-gnu/libkrb5.so.26.0.0
    7f0c0057a000-7f0c0057e000 r--p 0008b000 09:03 6431138                    /usr/lib/x86_64-linux-gnu/libkrb5.so.26.0.0
    7f0c0057e000-7f0c00580000 rw-p 0008f000 09:03 6431138                    /usr/lib/x86_64-linux-gnu/libkrb5.so.26.0.0
    7f0c00580000-7f0c00581000 rw-p 00000000 00:00 0
    7f0c00581000-7f0c00584000 r--p 00000000 09:03 6431140                    /usr/lib/x86_64-linux-gnu/libheimntlm.so.0.1.0
    7f0c00584000-7f0c00588000 r-xp 00003000 09:03 6431140                    /usr/lib/x86_64-linux-gnu/libheimntlm.so.0.1.0
    7f0c00588000-7f0c0058a000 r--p 00007000 09:03 6431140                    /usr/lib/x86_64-linux-gnu/libheimntlm.so.0.1.0
    7f0c0058a000-7f0c0058b000 ---p 00009000 09:03 6431140                    /usr/lib/x86_64-linux-gnu/libheimntlm.so.0.1.0
    7f0c0058b000-7f0c0058c000 r--p 00009000 09:03 6431140                    /usr/lib/x86_64-linux-gnu/libheimntlm.so.0.1.0
    7f0c0058c000-7f0c0058d000 rw-p 0000a000 09:03 6431140                    /usr/lib/x86_64-linux-gnu/libheimntlm.so.0.1.0
    7f0c0058d000-7f0c0058f000 rw-p 00000000 00:00 0
    7f0c0058f000-7f0c00592000 r--p 00000000 09:03 6424635                    /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    7f0c00592000-7f0c00599000 r-xp 00003000 09:03 6424635                    /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    7f0c00599000-7f0c0059c000 r--p 0000a000 09:03 6424635                    /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    7f0c0059c000-7f0c0059d000 r--p 0000c000 09:03 6424635                    /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    7f0c0059d000-7f0c0059e000 rw-p 0000d000 09:03 6424635                    /usr/lib/x86_64-linux-gnu/libkrb5support.so.0.1
    7f0c0059e000-7f0c005a0000 r--p 00000000 09:03 6425452                    /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
    7f0c005a0000-7f0c005a2000 r-xp 00002000 09:03 6425452                    /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
    7f0c005a2000-7f0c005a3000 r--p 00004000 09:03 6425452                    /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
    7f0c005a3000-7f0c005a4000 r--p 00004000 09:03 6425452                    /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
    7f0c005a4000-7f0c005a5000 rw-p 00005000 09:03 6425452                    /usr/lib/x86_64-linux-gnu/libcom_err.so.2.1
    7f0c005a5000-7f0c005a9000 r--p 00000000 09:03 6424779                    /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    7f0c005a9000-7f0c005c5000 r-xp 00004000 09:03 6424779                    /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    7f0c005c5000-7f0c005d2000 r--p 00020000 09:03 6424779                    /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    7f0c005d2000-7f0c005d3000 ---p 0002d000 09:03 6424779                    /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    7f0c005d3000-7f0c005d4000 r--p 0002d000 09:03 6424779                    /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    7f0c005d4000-7f0c005d5000 rw-p 0002e000 09:03 6424779                    /usr/lib/x86_64-linux-gnu/libk5crypto.so.3.1
    7f0c005d5000-7f0c005d6000 rw-p 00000000 00:00 0
    7f0c005d6000-7f0c005f8000 r--p 00000000 09:03 6424631                    /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    7f0c005f8000-7f0c00659000 r-xp 00022000 09:03 6424631                    /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    7f0c00659000-7f0c006a2000 r--p 00083000 09:03 6424631                    /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    7f0c006a2000-7f0c006a3000 ---p 000cc000 09:03 6424631                    /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    7f0c006a3000-7f0c006b1000 r--p 000cc000 09:03 6424631                    /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    7f0c006b1000-7f0c006b3000 rw-p 000da000 09:03 6424631                    /usr/lib/x86_64-linux-gnu/libkrb5.so.3.3
    7f0c006b3000-7f0c006b4000 r--p 00000000 09:03 6422768                    /usr/lib/x86_64-linux-gnu/libicudata.so.66.1
    7f0c006b4000-7f0c006b5000 r-xp 00001000 09:03 6422768                    /usr/lib/x86_64-linux-gnu/libicudata.so.66.1
    7f0c006b5000-7f0c02172000 r--p 00002000 09:03 6422768                    /usr/lib/x86_64-linux-gnu/libicudata.so.66.1
    7f0c02172000-7f0c02173000 r--p 01abe000 09:03 6422768                    /usr/lib/x86_64-linux-gnu/libicudata.so.66.1
    7f0c02173000-7f0c02174000 rw-p 01abf000 09:03 6422768                    /usr/lib/x86_64-linux-gnu/libicudata.so.66.1
    7f0c02174000-7f0c02176000 rw-p 00000000 00:00 0
    7f0c02176000-7f0c02177000 r--p 00000000 09:03 6424846                    /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.7
    7f0c02177000-7f0c0217f000 r-xp 00001000 09:03 6424846                    /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.7
    7f0c0217f000-7f0c02182000 r--p 00009000 09:03 6424846                    /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.7
    7f0c02182000-7f0c02183000 r--p 0000b000 09:03 6424846                    /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.7
    7f0c02183000-7f0c02184000 rw-p 0000c000 09:03 6424846                    /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1.0.7
    7f0c02184000-7f0c02186000 r--p 00000000 09:03 6430862                    /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    7f0c02186000-7f0c02188000 r-xp 00002000 09:03 6430862                    /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    7f0c02188000-7f0c02195000 r--p 00004000 09:03 6430862                    /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    7f0c02195000-7f0c02196000 r--p 00010000 09:03 6430862                    /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    7f0c02196000-7f0c02197000 rw-p 00011000 09:03 6430862                    /usr/lib/x86_64-linux-gnu/libpsl.so.5.3.2
    7f0c02197000-7f0c0219c000 r--p 00000000 09:03 6431153                    /usr/lib/x86_64-linux-gnu/librtmp.so.1
    7f0c0219c000-7f0c021ad000 r-xp 00005000 09:03 6431153                    /usr/lib/x86_64-linux-gnu/librtmp.so.1
    7f0c021ad000-7f0c021b4000 r--p 00016000 09:03 6431153                    /usr/lib/x86_64-linux-gnu/librtmp.so.1
    7f0c021b4000-7f0c021b5000 ---p 0001d000 09:03 6431153                    /usr/lib/x86_64-linux-gnu/librtmp.so.1
    7f0c021b5000-7f0c021b6000 r--p 0001d000 09:03 6431153                    /usr/lib/x86_64-linux-gnu/librtmp.so.1
    7f0c021b6000-7f0c021b7000 rw-p 0001e000 09:03 6431153                    /usr/lib/x86_64-linux-gnu/librtmp.so.1
    7f0c021b7000-7f0c021b9000 r--p 00000000 09:03 6425530                    /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.6
    7f0c021b9000-7f0c021be000 r-xp 00002000 09:03 6425530                    /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.6
    7f0c021be000-7f0c021d5000 r--p 00007000 09:03 6425530                    /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.6
    7f0c021d5000-7f0c021d6000 ---p 0001e000 09:03 6425530                    /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.6
    7f0c021d6000-7f0c021d7000 r--p 0001e000 09:03 6425530                    /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.6
    7f0c021d7000-7f0c021d8000 rw-p 0001f000 09:03 6425530                    /usr/lib/x86_64-linux-gnu/libidn2.so.0.3.6
    7f0c021d8000-7f0c021dd000 r--p 00000000 09:03 6431151                    /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.19.0
    7f0c021dd000-7f0c021f0000 r-xp 00005000 09:03 6431151                    /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.19.0
    7f0c021f0000-7f0c021fd000 r--p 00018000 09:03 6431151                    /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.19.0
    7f0c021fd000-7f0c02200000 r--p 00024000 09:03 6431151                    /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.19.0
    7f0c02200000-7f0c02201000 rw-p 00027000 09:03 6431151                    /usr/lib/x86_64-linux-gnu/libnghttp2.so.14.19.0
    7f0c02201000-7f0c02230000 r--p 00000000 09:03 6425582                    /usr/lib/x86_64-linux-gnu/libgnutls.so.30.27.0
    7f0c02230000-7f0c02352000 r-xp 0002f000 09:03 6425582                    /usr/lib/x86_64-linux-gnu/libgnutls.so.30.27.0
    7f0c02352000-7f0c023c3000 r--p 00151000 09:03 6425582                    /usr/lib/x86_64-linux-gnu/libgnutls.so.30.27.0
    7f0c023c3000-7f0c023c4000 ---p 001c2000 09:03 6425582                    /usr/lib/x86_64-linux-gnu/libgnutls.so.30.27.0
    7f0c023c4000-7f0c023d3000 r--p 001c2000 09:03 6425582                    /usr/lib/x86_64-linux-gnu/libgnutls.so.30.27.0
    7f0c023d3000-7f0c023d5000 rw-p 001d1000 09:03 6425582                    /usr/lib/x86_64-linux-gnu/libgnutls.so.30.27.0
    7f0c023d5000-7f0c023d9000 rw-p 00000000 00:00 0
    7f0c023d9000-7f0c023e6000 r--p 00000000 09:03 6431142                    /usr/lib/x86_64-linux-gnu/libgssapi.so.3.0.0
    7f0c023e6000-7f0c0240f000 r-xp 0000d000 09:03 6431142                    /usr/lib/x86_64-linux-gnu/libgssapi.so.3.0.0
    7f0c0240f000-7f0c0241a000 r--p 00036000 09:03 6431142                    /usr/lib/x86_64-linux-gnu/libgssapi.so.3.0.0
    7f0c0241a000-7f0c0241c000 r--p 00040000 09:03 6431142                    /usr/lib/x86_64-linux-gnu/libgssapi.so.3.0.0
    7f0c0241c000-7f0c0241e000 rw-p 00042000 09:03 6431142                    /usr/lib/x86_64-linux-gnu/libgssapi.so.3.0.0
    7f0c0241e000-7f0c02421000 r--p 00000000 09:03 6424664                    /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    7f0c02421000-7f0c02433000 r-xp 00003000 09:03 6424664                    /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    7f0c02433000-7f0c02439000 r--p 00015000 09:03 6424664                    /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    7f0c02439000-7f0c0243a000 r--p 0001a000 09:03 6424664                    /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    7f0c0243a000-7f0c0243b000 rw-p 0001b000 09:03 6424664                    /usr/lib/x86_64-linux-gnu/libsasl2.so.2.0.25
    7f0c0243b000-7f0c0243d000 r--p 00000000 09:03 6436896                    /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    7f0c0243d000-7f0c02442000 r-xp 00002000 09:03 6436896                    /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    7f0c02442000-7f0c02444000 r--p 00007000 09:03 6436896                    /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    7f0c02444000-7f0c02445000 r--p 00008000 09:03 6436896                    /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    7f0c02445000-7f0c02446000 rw-p 00009000 09:03 6436896                    /usr/lib/x86_64-linux-gnu/libOpenIPMIutils.so.0.0.1
    7f0c02446000-7f0c02451000 r--p 00000000 09:03 6422955                    /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    7f0c02451000-7f0c02483000 r-xp 0000b000 09:03 6422955                    /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    7f0c02483000-7f0c0248f000 r--p 0003d000 09:03 6422955                    /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    7f0c0248f000-7f0c02491000 r--p 00048000 09:03 6422955                    /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    7f0c02491000-7f0c02493000 rw-p 0004a000 09:03 6422955                    /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2.2
    7f0c02493000-7f0c02496000 r--p 00000000 09:03 6423499                    /usr/lib/x86_64-linux-gnu/liblzma.so.5.2.4
    7f0c02496000-7f0c024ae000 r-xp 00003000 09:03 6423499                    /usr/lib/x86_64-linux-gnu/liblzma.so.5.2.4
    7f0c024ae000-7f0c024b9000 r--p 0001b000 09:03 6423499                    /usr/lib/x86_64-linux-gnu/liblzma.so.5.2.4
    7f0c024b9000-7f0c024ba000 ---p 00026000 09:03 6423499                    /usr/lib/x86_64-linux-gnu/liblzma.so.5.2.4
    7f0c024ba000-7f0c024bb000 r--p 00026000 09:03 6423499                    /usr/lib/x86_64-linux-gnu/liblzma.so.5.2.4
    7f0c024bb000-7f0c024bc000 rw-p 00027000 09:03 6423499                    /usr/lib/x86_64-linux-gnu/liblzma.so.5.2.4
    7f0c024bc000-7f0c024be000 rw-p 00000000 00:00 0
    7f0c024be000-7f0c02523000 r--p 00000000 09:03 6422846                    /usr/lib/x86_64-linux-gnu/libicuuc.so.66.1
    7f0c02523000-7f0c02608000 r-xp 00065000 09:03 6422846                    /usr/lib/x86_64-linux-gnu/libicuuc.so.66.1
    7f0c02608000-7f0c0268e000 r--p 0014a000 09:03 6422846                    /usr/lib/x86_64-linux-gnu/libicuuc.so.66.1
    7f0c0268e000-7f0c0268f000 ---p 001d0000 09:03 6422846                    /usr/lib/x86_64-linux-gnu/libicuuc.so.66.1
    7f0c0268f000-7f0c026a1000 r--p 001d0000 09:03 6422846                    /usr/lib/x86_64-linux-gnu/libicuuc.so.66.1
    7f0c026a1000-7f0c026a2000 rw-p 001e2000 09:03 6422846                    /usr/lib/x86_64-linux-gnu/libicuuc.so.66.1
    7f0c026a2000-7f0c026a4000 rw-p 00000000 00:00 0
    7f0c026a4000-7f0c026a7000 r--p 00000000 09:03 6425666                    /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    7f0c026a7000-7f0c026b9000 r-xp 00003000 09:03 6425666                    /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    7f0c026b9000-7f0c026bd000 r--p 00015000 09:03 6425666                    /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    7f0c026bd000-7f0c026be000 r--p 00018000 09:03 6425666                    /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    7f0c026be000-7f0c026bf000 rw-p 00019000 09:03 6425666                    /usr/lib/x86_64-linux-gnu/libgcc_s.so.1
    7f0c026bf000-7f0c02755000 r--p 00000000 09:03 6425667                    /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    7f0c02755000-7f0c02846000 r-xp 00096000 09:03 6425667                    /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    7f0c02846000-7f0c0288f000 r--p 00187000 09:03 6425667                    /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    7f0c0288f000-7f0c02890000 ---p 001d0000 09:03 6425667                    /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    7f0c02890000-7f0c0289b000 r--p 001d0000 09:03 6425667                    /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    7f0c0289b000-7f0c0289e000 rw-p 001db000 09:03 6425667                    /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.28
    7f0c0289e000-7f0c028a1000 rw-p 00000000 00:00 0
    7f0c028a1000-7f0c028c3000 r--p 00000000 09:03 6433408                    /usr/lib/x86_64-linux-gnu/libc-2.31.so
    7f0c028c3000-7f0c02a3b000 r-xp 00022000 09:03 6433408                    /usr/lib/x86_64-linux-gnu/libc-2.31.so
    7f0c02a3b000-7f0c02a89000 r--p 0019a000 09:03 6433408                    /usr/lib/x86_64-linux-gnu/libc-2.31.so
    7f0c02a89000-7f0c02a8d000 r--p 001e7000 09:03 6433408                    /usr/lib/x86_64-linux-gnu/libc-2.31.so
    7f0c02a8d000-7f0c02a8f000 rw-p 001eb000 09:03 6433408                    /usr/lib/x86_64-linux-gnu/libc-2.31.so
    7f0c02a8f000-7f0c02a93000 rw-p 00000000 00:00 0
    7f0c02a93000-7f0c02a95000 r--p 00000000 09:03 6425600                    /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.9.0
    7f0c02a95000-7f0c02af9000 r-xp 00002000 09:03 6425600                    /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.9.0
    7f0c02af9000-7f0c02b21000 r--p 00066000 09:03 6425600                    /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.9.0
    7f0c02b21000-7f0c02b22000 r--p 0008d000 09:03 6425600                    /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.9.0
    7f0c02b22000-7f0c02b23000 rw-p 0008e000 09:03 6425600                    /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0.9.0
    7f0c02b23000-7f0c02b25000 rw-p 00000000 00:00 0
    7f0c02b25000-7f0c02b32000 r--p 00000000 09:03 6425534                    /usr/lib/x86_64-linux-gnu/libcurl.so.4.6.0
    7f0c02b32000-7f0c02b96000 r-xp 0000d000 09:03 6425534                    /usr/lib/x86_64-linux-gnu/libcurl.so.4.6.0
    7f0c02b96000-7f0c02bb1000 r--p 00071000 09:03 6425534                    /usr/lib/x86_64-linux-gnu/libcurl.so.4.6.0
    7f0c02bb1000-7f0c02bb5000 r--p 0008b000 09:03 6425534                    /usr/lib/x86_64-linux-gnu/libcurl.so.4.6.0
    7f0c02bb5000-7f0c02bb6000 rw-p 0008f000 09:03 6425534                    /usr/lib/x86_64-linux-gnu/libcurl.so.4.6.0
    7f0c02bb6000-7f0c02bb9000 r--p 00000000 09:03 6424671                    /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.10.12
    7f0c02bb9000-7f0c02bc1000 r-xp 00003000 09:03 6424671                    /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.10.12
    7f0c02bc1000-7f0c02bc4000 r--p 0000b000 09:03 6424671                    /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.10.12
    7f0c02bc4000-7f0c02bc5000 ---p 0000e000 09:03 6424671                    /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.10.12
    7f0c02bc5000-7f0c02bc6000 r--p 0000e000 09:03 6424671                    /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.10.12
    7f0c02bc6000-7f0c02bc7000 rw-p 0000f000 09:03 6424671                    /usr/lib/x86_64-linux-gnu/liblber-2.4.so.2.10.12
    7f0c02bc7000-7f0c02bd4000 r--p 00000000 09:03 6424674                    /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.10.12
    7f0c02bd4000-7f0c02c08000 r-xp 0000d000 09:03 6424674                    /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.10.12
    7f0c02c08000-7f0c02c17000 r--p 00041000 09:03 6424674                    /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.10.12
    7f0c02c17000-7f0c02c18000 ---p 00050000 09:03 6424674                    /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.10.12
    7f0c02c18000-7f0c02c1a000 r--p 00050000 09:03 6424674                    /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.10.12
    7f0c02c1a000-7f0c02c1b000 rw-p 00052000 09:03 6424674                    /usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2.10.12
    7f0c02c1b000-7f0c02c1d000 rw-p 00000000 00:00 0
    7f0c02c1d000-7f0c02c29000 r--p 00000000 09:03 6430854                    /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.0
    7f0c02c29000-7f0c02c5d000 r-xp 0000c000 09:03 6430854                    /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.0
    7f0c02c5d000-7f0c02c71000 r--p 00040000 09:03 6430854                    /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.0
    7f0c02c71000-7f0c02c72000 r--p 00053000 09:03 6430854                    /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.0
    7f0c02c72000-7f0c02c73000 rw-p 00054000 09:03 6430854                    /usr/lib/x86_64-linux-gnu/libevent-2.1.so.7.0.0
    7f0c02c73000-7f0c02c75000 r--p 00000000 09:03 6436893                    /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    7f0c02c75000-7f0c02c79000 r-xp 00002000 09:03 6436893                    /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    7f0c02c79000-7f0c02c7a000 r--p 00006000 09:03 6436893                    /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    7f0c02c7a000-7f0c02c7b000 ---p 00007000 09:03 6436893                    /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    7f0c02c7b000-7f0c02c7c000 r--p 00007000 09:03 6436893                    /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    7f0c02c7c000-7f0c02c7d000 rw-p 00008000 09:03 6436893                    /usr/lib/x86_64-linux-gnu/libOpenIPMIposix.so.0.0.1
    7f0c02c7d000-7f0c02cab000 r--p 00000000 09:03 6436891                    /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    7f0c02cab000-7f0c02d28000 r-xp 0002e000 09:03 6436891                    /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    7f0c02d28000-7f0c02d66000 r--p 000ab000 09:03 6436891                    /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    7f0c02d66000-7f0c02d7d000 r--p 000e8000 09:03 6436891                    /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    7f0c02d7d000-7f0c02d82000 rw-p 000ff000 09:03 6436891                    /usr/lib/x86_64-linux-gnu/libOpenIPMI.so.0.0.5
    7f0c02d82000-7f0c02d88000 rw-p 00000000 00:00 0
    7f0c02d88000-7f0c02d95000 r--p 00000000 09:03 6424849                    /usr/lib/x86_64-linux-gnu/libssh.so.4.8.4
    7f0c02d95000-7f0c02dd6000 r-xp 0000d000 09:03 6424849                    /usr/lib/x86_64-linux-gnu/libssh.so.4.8.4
    7f0c02dd6000-7f0c02df1000 r--p 0004e000 09:03 6424849                    /usr/lib/x86_64-linux-gnu/libssh.so.4.8.4
    7f0c02df1000-7f0c02df2000 ---p 00069000 09:03 6424849                    /usr/lib/x86_64-linux-gnu/libssh.so.4.8.4
    7f0c02df2000-7f0c02df4000 r--p 00069000 09:03 6424849                    /usr/lib/x86_64-linux-gnu/libssh.so.4.8.4
    7f0c02df4000-7f0c02df6000 rw-p 0006b000 09:03 6424849                    /usr/lib/x86_64-linux-gnu/libssh.so.4.8.4
    7f0c02df6000-7f0c02e0b000 r--p 00000000 09:03 6436868                    /usr/lib/x86_64-linux-gnu/libnetsnmp.so.35.0.0
    7f0c02e0b000-7f0c02e85000 r-xp 00015000 09:03 6436868                    /usr/lib/x86_64-linux-gnu/libnetsnmp.so.35.0.0
    7f0c02e85000-7f0c02eaa000 r--p 0008f000 09:03 6436868                    /usr/lib/x86_64-linux-gnu/libnetsnmp.so.35.0.0
    7f0c02eaa000-7f0c02eab000 ---p 000b4000 09:03 6436868                    /usr/lib/x86_64-linux-gnu/libnetsnmp.so.35.0.0
    7f0c02eab000-7f0c02eac000 r--p 000b4000 09:03 6436868                    /usr/lib/x86_64-linux-gnu/libnetsnmp.so.35.0.0
    7f0c02eac000-7f0c02eaf000 rw-p 000b5000 09:03 6436868                    /usr/lib/x86_64-linux-gnu/libnetsnmp.so.35.0.0
    7f0c02eaf000-7f0c02f74000 rw-p 00000000 00:00 0
    7f0c02f74000-7f0c02fdc000 r-xp 00000000 09:03 6436884                    /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    7f0c02fdc000-7f0c031db000 ---p 00068000 09:03 6436884                    /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    7f0c031db000-7f0c031dc000 r--p 00067000 09:03 6436884                    /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    7f0c031dc000-7f0c031e3000 rw-p 00068000 09:03 6436884                    /usr/lib/x86_64-linux-gnu/libodbc.so.2.0.0
    7f0c031e3000-7f0c031e7000 rw-p 00000000 00:00 0
    7f0c031e7000-7f0c03214000 r--p 00000000 09:03 6422694                    /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.10
    7f0c03214000-7f0c0333e000 r-xp 0002d000 09:03 6422694                    /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.10
    7f0c0333e000-7f0c03395000 r--p 00157000 09:03 6422694                    /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.10
    7f0c03395000-7f0c0339e000 r--p 001ad000 09:03 6422694                    /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.10
    7f0c0339e000-7f0c0339f000 rw-p 001b6000 09:03 6422694                    /usr/lib/x86_64-linux-gnu/libxml2.so.2.9.10
    7f0c0339f000-7f0c033a1000 rw-p 00000000 00:00 0
    7f0c033a1000-7f0c033a5000 r--p 00000000 09:03 6433436                    /usr/lib/x86_64-linux-gnu/libresolv-2.31.so
    7f0c033a5000-7f0c033b5000 r-xp 00004000 09:03 6433436                    /usr/lib/x86_64-linux-gnu/libresolv-2.31.so
    7f0c033b5000-7f0c033b9000 r--p 00014000 09:03 6433436                    /usr/lib/x86_64-linux-gnu/libresolv-2.31.so
    7f0c033b9000-7f0c033ba000 r--p 00017000 09:03 6433436                    /usr/lib/x86_64-linux-gnu/libresolv-2.31.so
    7f0c033ba000-7f0c033bb000 rw-p 00018000 09:03 6433436                    /usr/lib/x86_64-linux-gnu/libresolv-2.31.so
    7f0c033bb000-7f0c033bd000 rw-p 00000000 00:00 0
    7f0c033bd000-7f0c033be000 r--p 00000000 09:03 6433423                    /usr/lib/x86_64-linux-gnu/libdl-2.31.so
    7f0c033be000-7f0c033c0000 r-xp 00001000 09:03 6433423                    /usr/lib/x86_64-linux-gnu/libdl-2.31.so
    7f0c033c0000-7f0c033c1000 r--p 00003000 09:03 6433423                    /usr/lib/x86_64-linux-gnu/libdl-2.31.so
    7f0c033c1000-7f0c033c2000 r--p 00003000 09:03 6433423                    /usr/lib/x86_64-linux-gnu/libdl-2.31.so
    7f0c033c2000-7f0c033c3000 rw-p 00004000 09:03 6433423                    /usr/lib/x86_64-linux-gnu/libdl-2.31.so
    7f0c033c3000-7f0c033c5000 rw-p 00000000 00:00 0
    7f0c033c5000-7f0c0343d000 r--p 00000000 09:03 6426057                    /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1
    7f0c0343d000-7f0c035d8000 r-xp 00078000 09:03 6426057                    /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1
    7f0c035d8000-7f0c03669000 r--p 00213000 09:03 6426057                    /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1
    7f0c03669000-7f0c03695000 r--p 002a3000 09:03 6426057                    /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1
    7f0c03695000-7f0c03697000 rw-p 002cf000 09:03 6426057                    /usr/lib/x86_64-linux-gnu/libcrypto.so.1.1
    7f0c03697000-7f0c0369b000 rw-p 00000000 00:00 0
    7f0c0369b000-7f0c036b7000 r--p 00000000 09:03 6426059                    /usr/lib/x86_64-linux-gnu/libssl.so.1.1
    7f0c036b7000-7f0c03706000 r-xp 0001c000 09:03 6426059                    /usr/lib/x86_64-linux-gnu/libssl.so.1.1
    7f0c03706000-7f0c03720000 r--p 0006b000 09:03 6426059                    /usr/lib/x86_64-linux-gnu/libssl.so.1.1
    7f0c03720000-7f0c03721000 ---p 00085000 09:03 6426059                    /usr/lib/x86_64-linux-gnu/libssl.so.1.1
    7f0c03721000-7f0c0372a000 r--p 00085000 09:03 6426059                    /usr/lib/x86_64-linux-gnu/libssl.so.1.1
    7f0c0372a000-7f0c0372e000 rw-p 0008e000 09:03 6426059                    /usr/lib/x86_64-linux-gnu/libssl.so.1.1
    7f0c0372e000-7f0c0373b000 r--p 00000000 09:03 6433424                    /usr/lib/x86_64-linux-gnu/libm-2.31.so
    7f0c0373b000-7f0c037e2000 r-xp 0000d000 09:03 6433424                    /usr/lib/x86_64-linux-gnu/libm-2.31.so
    7f0c037e2000-7f0c0387b000 r--p 000b4000 09:03 6433424                    /usr/lib/x86_64-linux-gnu/libm-2.31.so
    7f0c0387b000-7f0c0387c000 r--p 0014c000 09:03 6433424                    /usr/lib/x86_64-linux-gnu/libm-2.31.so
    7f0c0387c000-7f0c0387d000 rw-p 0014d000 09:03 6433424                    /usr/lib/x86_64-linux-gnu/libm-2.31.so
    7f0c0387d000-7f0c0387f000 r--p 00000000 09:03 6425571                    /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
    7f0c0387f000-7f0c03890000 r-xp 00002000 09:03 6425571                    /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
    7f0c03890000-7f0c03896000 r--p 00013000 09:03 6425571                    /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
    7f0c03896000-7f0c03897000 ---p 00019000 09:03 6425571                    /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
    7f0c03897000-7f0c03898000 r--p 00019000 09:03 6425571                    /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
    7f0c03898000-7f0c03899000 rw-p 0001a000 09:03 6425571                    /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
    7f0c03899000-7f0c0389f000 r--p 00000000 09:03 6433435                    /usr/lib/x86_64-linux-gnu/libpthread-2.31.so
    7f0c0389f000-7f0c038b0000 r-xp 00006000 09:03 6433435                    /usr/lib/x86_64-linux-gnu/libpthread-2.31.so
    7f0c038b0000-7f0c038b6000 r--p 00017000 09:03 6433435                    /usr/lib/x86_64-linux-gnu/libpthread-2.31.so
    7f0c038b6000-7f0c038b7000 r--p 0001c000 09:03 6433435                    /usr/lib/x86_64-linux-gnu/libpthread-2.31.so
    7f0c038b7000-7f0c038b8000 rw-p 0001d000 09:03 6433435                    /usr/lib/x86_64-linux-gnu/libpthread-2.31.so
    7f0c038b8000-7f0c038bc000 rw-p 00000000 00:00 0
    7f0c038bc000-7f0c038e3000 r--p 00000000 09:03 6436866                    /usr/lib/x86_64-linux-gnu/libmysqlclient.so.21.2.28
    7f0c038e3000-7f0c03a08000 r-xp 00027000 09:03 6436866                    /usr/lib/x86_64-linux-gnu/libmysqlclient.so.21.2.28
    7f0c03a08000-7f0c03cf4000 r--p 0014c000 09:03 6436866                    /usr/lib/x86_64-linux-gnu/libmysqlclient.so.21.2.28
    7f0c03cf4000-7f0c03cf5000 ---p 00438000 09:03 6436866                    /usr/lib/x86_64-linux-gnu/libmysqlclient.so.21.2.28
    7f0c03cf5000-7f0c03cf9000 r--p 00438000 09:03 6436866                    /usr/lib/x86_64-linux-gnu/libmysqlclient.so.21.2.28
    7f0c03cf9000-7f0c03fea000 rw-p 0043c000 09:03 6436866                    /usr/lib/x86_64-linux-gnu/libmysqlclient.so.21.2.28
    7f0c03fea000-7f0c03ff2000 rw-p 00000000 00:00 0
    7f0c03fff000-7f0c04000000 r--p 00000000 09:03 6433404                    /usr/lib/x86_64-linux-gnu/ld-2.31.so
    7f0c04000000-7f0c04023000 r-xp 00001000 09:03 6433404                    /usr/lib/x86_64-linux-gnu/ld-2.31.so
    7f0c04023000-7f0c0402b000 r--p 00024000 09:03 6433404                    /usr/lib/x86_64-linux-gnu/ld-2.31.so
    7f0c0402b000-7f0c0402c000 rw-s 00000000 00:01 131074                     /SYSV00000000 (deleted)
    7f0c0402c000-7f0c0402d000 r--p 0002c000 09:03 6433404                    /usr/lib/x86_64-linux-gnu/ld-2.31.so
    7f0c0402d000-7f0c0402e000 rw-p 0002d000 09:03 6433404                    /usr/lib/x86_64-linux-gnu/ld-2.31.so
    7f0c0402e000-7f0c0402f000 rw-p 00000000 00:00 0
    7ffcb8367000-7ffcb8388000 rw-p 00000000 00:00 0                          [stack]
    7ffcb8388000-7ffcb838b000 r--p 00000000 00:00 0                          [vvar]
    7ffcb838b000-7ffcb838c000 r-xp 00000000 00:00 0                          [vdso]
    ffffffffff600000-ffffffffff601000 --xp 00000000 00:00 0                  [vsyscall]
    Please consider attaching a disassembly listing to your bug report.
    This listing can be produced with, e.g., objdump -DSswx zabbix_server.
    Elastic is used for history storage?
    Got signal [signal:11(SIGSEGV),reason:1,refaddr:0x15]. Crashing ...​
    Very long shot, but I have a feeling that you may need to upgrade that Elastic also...
    Eventho https://www.zabbix.com/documentation...c_search_setup does not specify version, there is mentioned in libcurl requirements and in that backtrace it also mentions elastic version extraction...
    libcurl Required for web monitoring, VMware monitoring, SMTP authentication, web.page.* Zabbix agent items, HTTP agent items and Elasticsearch (if used). Version 7.28.0 or higher is recommended.
    Libcurl version requirements:
    - SMTP authentication: version 7.20.0 or higher
    - Elasticsearch: version 7.28.0 or higher
    but I may aswell be very wrong here, not using ES...
