I get this error when trying to install on suse 9.2:
error: Invalid MySQL directory - unable to find mysql.h
I am stuck on this, thanks for the help.
I am using this to configer:
./configure --with-mysql --with-net-snmp
My log is:
linux:/home/zabbix/zabbix # ./configure --with-mysql --with-net-snmp
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for main in -lsocket... no
checking for main in -lkstat... no
checking for main in -lnsl... yes
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking for unistd.h... (cached) yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking syslog.h usability... yes
checking syslog.h presence... yes
checking for syslog.h... yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking for sys/types.h... (cached) yes
checking for sys/stat.h... (cached) yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking dirent.h usability... yes
checking dirent.h presence... yes
checking for dirent.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking mtent.h usability... no
checking mtent.h presence... no
checking for mtent.h... no
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/pstat.h usability... no
checking sys/pstat.h presence... no
checking for sys/pstat.h... no
checking sys/sysinfo.h usability... yes
checking sys/sysinfo.h presence... yes
checking for sys/sysinfo.h... yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking for sys/socket.h... (cached) yes
checking sys/loadavg.h usability... no
checking sys/loadavg.h presence... no
checking for sys/loadavg.h... no
checking for netinet/in.h... (cached) yes
checking for arpa/inet.h... (cached) yes
checking sys/swap.h usability... yes
checking sys/swap.h presence... yes
checking for sys/swap.h... yes
checking sys/vmmeter.h usability... no
checking sys/vmmeter.h presence... no
checking for sys/vmmeter.h... no
checking for strings.h... (cached) yes
checking sys/sysctl.h usability... yes
checking sys/sysctl.h presence... yes
checking for sys/sysctl.h... yes
checking vm/vm_param.h usability... no
checking vm/vm_param.h presence... no
checking for vm/vm_param.h... no
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking kstat.h usability... no
checking kstat.h presence... no
checking for kstat.h... no
checking sys/syscall.h usability... yes
checking sys/syscall.h presence... yes
checking for sys/syscall.h... yes
checking sys/sysmacros.h usability... yes
checking sys/sysmacros.h presence... yes
checking for sys/sysmacros.h... yes
checking sys/procfs.h usability... yes
checking sys/procfs.h presence... yes
checking for sys/procfs.h... yes
checking for an ANSI C-conforming const... yes
checking for pid_t... yes
checking for socklen_t... yes
checking for /proc filesystem... yes
checking for file /proc/1/status... yes
checking for file /proc/0/psinfo... no
checking for file /proc/loadavg... yes
checking for file /proc/net/dev... yes
checking for mem_unit in struct sysinfo... yes
checking for freeswap in struct sysinfo... yes
checking for function setpriority() in sys/resource.h... yes
checking for function sysconf() in unistd.h... yes
checking for macro __va_copy() in stdarg.h... yes
checking for vmtotal in struct sys/vmmeter.h... no
checking for struct swaptable in sys/swap.h... no
checking for totalswap in struct sysinfo... yes
checking for function sysctl (KERN_BOOTTIME)... no
checking for function sysctl (KERN_MAXFILES)... no
checking for function sysctl (KERN_MAXPROC)... no
checking for function seteuid()... yes
checking for function setproctitle()... no
checking for totalram in struct sysinfo... yes
checking for sharedram in struct sysinfo... yes
checking for bufferram in struct sysinfo... yes
checking for freeram in struct sysinfo... yes
checking for uptime in struct sysinfo... yes
checking for procs in struct sysinfo... yes
checking return type of signal handlers... void
checking for getloadavg... yes
checking for socket... yes
checking for strtod... yes
checking for snprintf... yes
checking for vasprintf... yes
checking for asprintf... yes
checking for vsnprintf... yes
checking for MySQL support... no
configure: error: Invalid MySQL directory - unable to find mysql.h
My log is:
