Zabbix 6.2 server is not running
  • punch07
    • Dec 2022
    I have installed Zabbix on Ubuntu but getting error Server can't run. Please help me fix this
  • Stewie
    • Dec 2022
    What does the logs say about not starting? Mostly the reason of not starting can be red there....
    • Stewie
      • Dec 2022
      Do a
      tail -f /var/log/zabbix/zabbix_server.log
      In terminal, and have a look at the output.​
      • punch07
        • Dec 2022
        Originally posted by Stewie
        Do a
        Last login: Thu Dec 15 08:47:28 2022 from 172.16.128.101
        huythai@huythai:~$ sudo tail -f /var/log/zabbix/zabbix_server.log
        [sudo] password for huythai:
        16978:20221216:005015.524 [Z3001] connection to database 'zabbix' failed: [1045 ] Access denied for user 'zabbix'@'localhost' (using password: NO)
        16978:20221216:005015.524 database is down: reconnecting in 10 seconds
        16978:20221216:005025.525 [Z3001] connection to database 'zabbix' failed: [1045 ] Access denied for user 'zabbix'@'localhost' (using password: NO)
        16978:20221216:005025.525 database is down: reconnecting in 10 seconds
        16978:20221216:005035.525 [Z3001] connection to database 'zabbix' failed: [1045 ] Access denied for user 'zabbix'@'localhost' (using password: NO)
        16978:20221216:005035.525 database is down: reconnecting in 10 seconds
        16978:20221216:005045.526 [Z3001] connection to database 'zabbix' failed: [1045 ] Access denied for user 'zabbix'@'localhost' (using password: NO)
        16978:20221216:005045.526 database is down: reconnecting in 10 seconds
        16978:20221216:005055.527 [Z3001] connection to database 'zabbix' failed: [1045 ] Access denied for user 'zabbix'@'localhost' (using password: NO)
        16978:20221216:005055.527 database is down: reconnecting in 10 seconds
        16978:20221216:005105.528 [Z3001] connection to database 'zabbix' failed: [1045] Access denied for user 'zabbix'@'localhost' (using password: NO)
        16978:20221216:005105.528 database is down: reconnecting in 10 seconds
        16978:20221216:005115.528 [Z3001] connection to database 'zabbix' failed: [1045] Access denied for user 'zabbix'@'localhost' (using password: NO)
        16978:20221216:005115.528 database is down: reconnecting in 10 seconds
        16978:20221216:005125.529 [Z3001] connection to database 'zabbix' failed: [1045] Access denied for user 'zabbix'@'localhost' (using password: NO)
        16978:20221216:005125.529 database is down: reconnecting in 10 seconds
        • waleedmortaja
          • Dec 2022
          Zabbix Server is not able to reach the database. Make sure the database services is running and make sure you have configured the database name, username and password in zabbix_server config file.
          If you have mariadb, you can run it (and enable it to run on every server boot) using
          systemctl enable --now mariadb
          The default path for zabbix_server config is
          /etc/zabbix/zabbix_server.conf
          In general, make sure that you did not miss any step in the installation instructions.
