How to properly declare variable as host in zabbix_sender
  • Stewie
    • Dec 2022
    I'm trying to iterate over a list with ip addresses in conjunction with zabbix_sender like so:
    #!/bin/bash
    cat list.txt | while read card
    do
    echo $card
    rx1=$(invoke -a $card 3302448@0000:00:00? | awk '{ print $7}' |tail -n +2)
    zabbix_sender -z 10.160.0.121 -s $card -k receive.power1 -o $rx1
    rx2=$(invoke -a $card 3302448@0000:00:00? | awk '{ print $7}' |tail -n +2)
    zabbix_sender -z 10.160.0.121 -s 172.16.1.116 -k receive.power1 -o $rx1
    done​
    The list.txt just consists of:
    172.16.1.116
    172.16.1.117
    172.16.1.118
    172.16.1.119
    etc.
    Upon executing the script, the response is as follows:
    172.16.1.116 (comes from echo $card line in script)
    info from server: "processed: 0; failed: 1; total: 1; seconds spent: 0.000022" sent: 1; skipped: 0; total: 1
    info from server: "processed: 1; failed: 0; total: 1; seconds spent: 0.000065" sent: 1; skipped: 0; total: 1
    So zabbix_sender with variable $card fails and zabbix_sender with plain IP address works.
    Could someone enlighten me on how to encapsulate this variable properly if bare $card variable is not working?
    I've tried $("card"), ${"card"}, ($card), "($card)"
    The manual does not describe in any way shape or form the use of variables in zabbix_sender, oddly enough the -o $rx1 as variable works like a charm and is correctly called as such.
    Works like charm for me just as it is ... *ok I just usend some random stuff for values and echoed out the end commands...
    Maybe add -vv at the and of zabbix_sender command to get some more output ...
