Show Low Disk Space
  • Nefariousparity
    • Dec 2022
    Show Low Disk Space
    Hello, we have been using Zabbix for years, and recently upgraded from version 4 to 6. Completely fresh install, and upgraded all our agents, on all servers and re imported all VM's. What we are struggling with is, no longer do VM's running out of disk space showing on the dashboard? We are using templates, Linux Agent, ICMP, and SSL external Check.
    This newly created VM I was using to test some new SSL stuff, but also disk space is showing here, and staying up here. Sometimes VM's show here, but leave here after awhile though they are not freeing up disk space.
    Here is my current widget settings.
    I did go and create a fake file to fill the disk of another Vm, in which it did show up here for a few hours and then went away.
    Please help we are missing when VM's fill up on drive sapce, or even our Bare Metal Servers. Lastly we are using a custom template we made that combines Linux Agent, ICMP, and SSL External check called "arc web sip".
    Thank you!
