Autoregistration actions execution order
  • yurtesen
    • Aug 2008
    • 130
    I am trying to understand autoregistration a little bit better.
    * I assume only 1 action (first match) is executed per autoregistration attempt. Is this correct?
    * If there are multiple autoregistration actions with matching conditions. For example metadata `foobar` and 2 separate actions where one says `contains foo` and other has condition `contains bar` which one is executed?
    Thanks​
  • Answer selected by yurtesen at 25-11-2025, 12:53.
    cyber
    • 5002
    Why do you assume that? IIRC all matching actions are executed.
    I am pretty sure that action with lower ID gets executed first,
      • 5002
      • yurtesen
        • Aug 2008
        • 130
        Simply because there is no mention of such possibility in the manual:
        But thanks for clarifying the issue. Certainly things are more flexible if all matching actions are executed.
        • mircea-c
          • Nov 2025
          Going to revive this old post to ask if there's any source for this claim, besides going to dig through the source code.
          Would be great to be certain without having to test this every time a major version is released.
            • 5002
            No, there is nothing more than experience and gut feeling.. I think there are other things in the product that behave same way... if listed, similar things ordered by ID etc.. Like... if you have 2 tags with same name and different value in event... and in some action operation you refer to that tag by name ({EVENT.TAGS.<tag name>})... which one pops up? The one with lower ID..
