Line missing in regex preprocessing item eventlog
  • Treblig
    • Apr 2022
    I want to extract "nom du compte .*" and PCAppelant with regex "Compte\sverrouillé.*\n+.*\n+.(.*)\n+.*\s+(.*) " OUTPUT \1 \2 in preprocessing from the log below. eventlog[Security,,,,4740,,skip]
    Un compte d’utilisateur a été verrouillé.
    Sujet :
    ID de sécurité : AUTORITE NT\Système
    Nom du compte : SERVEUR$
    Domaine du compte : DOMAINE
    ID d’ouverture de session : xxxxx
    Compte verrouillé :
    ID de sécurité : Domain\AccountName
    Nom du compte : AccountName
    Informations supplémentaires :
    Nom de l’ordinateur de l’appelant : PCName
    All tests are OK but that's my result :
    Nom du compte : PCname
    I should obtain
    If someone have an idea.
    Thanks in advance.
  • Yafimm
    • May 2022
    • 9
    To extract the "nom du compte" and "nom de l'ordinateur de l'appelant" from the log text using a regular expression, you can use the following pattern:
    Compte verrouillé.*\n+.*\n+.*\n+.*\s+(.*)\n+.*\s+(.*)
    This regular expression will match the following text: "Compte verrouillé", followed by any number of lines, followed by the "nom du compte" and "nom de l'ordinateur de l'appelant" values. The first group (\1) will contain the "nom du compte" value, and the second group (\2) will contain the "nom de l'ordinateur de l'appelant" value.
    To use this regular expression in a preprocessing rule in Zabbix, you can use the following syntax:
    regexp(eventlog[Security,,,,4740,,skip],Compte verrouillé.*\n+.*\n+.*\n+.*\s+(.*)\n+.*\s+(.*))
    This will apply the regular expression to the "eventlog[Security,,,,4740,,skip]" value and return the matched groups as output. The first group (\1) will be returned as the first value, and the second group (\2) will be returned as the second value.
    I hope this helps! Let me know if you have any questions.
    • FriedaF
      • Dec 2022
      That's great. I was impressed by your writing. I am happy to see such a topic. Please come to my blog and read it.
      • Treblig
        • Apr 2022
        Hi, thanks for your help.
        it doesn’t work, I don’t have any error but no data collected.
        i literally write
        regexp(eventlog[Security,,,,4740,,], Compte\sverrouillé.*\n+.*\n+(.*)\n+.*\s+(.*))
        in a preprocessing rule and add \1 \2 in output
        it’s Ok ?
