Zabbix internal check for queue doesnt seem to work
  • zsuna
    • Dec 2022
    • 11
    according to https://www.zabbix.com/documentation...types/internal
    zabbix[queue,<from>,<to>]
    Number of monitored items in the queue which are delayed at least by <from> seconds but less than by <to> seconds. Integer from - default: 6 seconds
    to - default: infinity
    Time-unit symbols (s,m,h,d,w) are supported for these parameters.
    it should be possible to create an internal zabbix item with the key zabbix[queue,10m], which should display the amount of items inside the queue for more than 10 minutes.
    However, no matter what values i add for <from> and <to>, the check keeps ignoring them. It will ALWAYS display zabbix[queue], no matter what numbers are given.
    Item values:
    item definitions:​
    Is this a bug or working as intended? What am i missing here?
    Br,
    Zarko
  • Markku
    • Sep 2018
    • 1784
    Click image for larger version  Name:	image.png Views:	0 Size:	127.2 KB ID:	456669
    "An item with key "zabbix[queue,10m]" already exists on the host "Zabbix server"." it says here when trying to add duplicate item key. This is 6.4.0beta5.
    Workaround, if you really want to create a duplicate item: use zabbix[queue,10m,]
    You didn't mention your Zabbix version but the usual comment whenever encountering strange problem is to upgrade to the latest version in that series.
    Markku
    • zsuna
      • Dec 2022
      • 11
      i don´t have a problem with duplicate items...
      zabbix[queue,10m] yields the same result as zabbix[queue], but it should only note my current 48 items which are in queue for more than 10 minutes.
      Br, Zsuna
      • Markku
        • Sep 2018
        • 1784
        So, how many items do you have that have been in the queue less than 10 minutes?
        Markku
        • zsuna
          • Dec 2022
          • 11
          Currently there are 48 in the queue for longer than 10 minutes.
          But the item shows 600+
          Br,
          Zarko
          • Markku
            • Sep 2018
            • 1784
            You still didn't say your Zabbix version
            Markku
            • zsuna
              • Dec 2022
              • 11
              Our Zabbix Version is 6.0.12
              • Markku
                • Sep 2018
                • 1784
                FWIW, works correctly on 6.4.0beta5.
                Markku
                • zsuna
                  • Dec 2022
                  • 11
                  Ty.
                  So this looks like to be a bug in 6.0.12 then.
                  Is there a list of bugfixes somewhere to find? So i can lookup when this got fixed.
                  Maybe if you by chance have a 6.0.12 version, could you check if it works there properly aswell? just to rule out some setup problem.
                  Br, Zsuna
                  • Markku
                    • Sep 2018
                    • 1784
                    Also works here on 6.0.11, with "from" values of empty, 3m and 10m: they are not identical and they reflect the real situation in the queue.
                    Markku
                    • zsuna
                      • Dec 2022
                      • 11
                      Then i guess something else is wrong.
                      We are using Zabbix Proxy, do i need change my item for this somehow?
                      Br, zsuna
                      • Markku
                        • Sep 2018
                        • 1784
                        Right, sorry, I missed the proxy detail from your images. I only tested with the internal items on the server.
                        If you think your configurations are correct and you interpret the queue information in the GUI correctly, you can always open an issue at https://support.zabbix.com.
                        Markku
                        • zsuna
                          • Dec 2022
                          • 11
                          Thank you, i will open up an issue.
                          Br, zsuna
                          • Markku
                            • Sep 2018
                            • 1784
                            Forgot to say that the release notes are here, with list of fixed issues: https://www.zabbix.com/release_notes
                            Markku
                            • zsuna
                              • Dec 2022
                              • 11
                              #15
                              the issue was resolved - problem were some network issues with routing to the proper proxy.
                              Br, Zarko
                              • pcyran94
                                pcyran94 commented
                                Could you please expand your conclusion? I have similar symptoms, that items for proxies queue show totaly different values than Queue tab. Same on 6.4.1 and 7.0.0.
