create new hosts based on LLD
  • baramann
    • Jan 2021
    • 9
    Hi@all,
    i try to create new hosts via LLD. to do this, i trigger a LLD rule an a host which returns this json:
    { "data":[
    "NewSQLHost": "test1",
    "{#sqlClusterRole}": "SQL Server (test1)",
    "{#sqlResName}": "test1",
    "{#sqlResNameDNS}": "test1",
    "{#sqlResNameIP}": "10.10.10.10"
    "NewSQLHost": "test2",
    "{#sqlClusterRole}": "SQL Server (test2)",
    "{#sqlResName}": "sqltest2",
    "{#sqlResNameDNS}": "sqltest2",
    "{#sqlResNameIP}": "1.2.3.4"
    ​Next, my goal is, that based on this, 2 new hosts are created. In the LLD is set as LLD Macro:
    Macro Json Path
    {#SQLNAME} --> $.[].NewSQLHost
    The Host prototype use for the Hostname: {#SQLNAME}
    But, i got the error von LLD:
    Cannot create host "{#SQLNAME}": name contains invalid character '{'.
    What do i wrong???
    Thank for hints!
    bjoern
  • baramann
    • Jan 2021
    • 9
    So, i found the solution - the spelling of macro names in the json need names without the {#} - then it works :-)
    Correkt json:
    { "data":[
    "sqlClusterRole": "SQL Server (test1)",
    "sqlResName": "test1",
    "sqlResNameDNS": "test1",
    "sqlResNameIP": "10.10.10.10"
    "sqlClusterRole": "SQL Server (test2)",
    "sqlResName": "sqltest2",
    "sqlResNameDNS": "sqltest2",
    "sqlResNameIP": "1.2.3.4"
    Then i can use them in die LLD macro and the new hosts were correct created.
    Macro Json Path
    {#SQLIP} --> $.sqlResNameIP
    {#SQLNAME} --> $.NewSQLHost
    I think this a little bit strange because in "normal" LLD for items and triggers, the {#} can be used . My Zabbix version is 6.0.12​
      LLD macros are in capital letters.... Think about it ,, Test it... Maybe you dont need that LLD macro pointing after all...
