Help with how I monitor a website that has login credentials.
  • greavette
    • Jul 2015
    • 82
    Hello Forum,
    I'm using Zabbix version 6 LTS
    I have a locally hosted Unifi Dashboard website which shows me the status (online or offline) status of each of my Unfi hardware devices.
    I have a local website that requires me to log in. I followed this post - https://bestmonitoringtools.com/zabb...with-examples/ on how to set up website monitoring with login.
    I created 3 steps:
    1. see if website URL is available
    2. login to website
    3. Check for any offline status on the page
    The page I'm monitoring looks as follows:
    I would like to focus in on the Status for each device. I'm looking for any device in this column with the word Offline. How do I create a step that can find this Offline word anywhere in this column.
    I did an inspect of the page and found the following:
    "data-label="Online""
    My first step is for the login credentials on the website. My Second step is the dashboard that's seen after I login. Do I add a Required String to the second step to ensure I'm on the Dahboard page? I tried adding some text to search for with a Required Status Cod of 200 but Zabbix says it can't find the text string I'm searching for?
    Thank you.​
