proc.num syntax question
  • TL168
    • Dec 2022
    hi all,
    I am new to zabbix, may i know can i user wildcard in user field in pronum[]
    e.g.
    my process may be run by user tom or tom123, can i set the syntax like this?
    proc.num[processA,tom*]
    if it is not supported, what alternative is suggested?
    Thanks a lot in advance .
    No.. it is not a regex (https://www.zabbix.com/documentation...t#process-data). But if its just those 2 names, you can leave username empty.
