OpenSSL dependency error while installing 6.2 Agent on Cent OS 7
  • Bs_sousa
    • Dec 2022
    When I try to install the version 6.2 zabbix agent on a Cent OS 7 server I get the following errors
    --> Finished Dependency Resolution
    Error: Package: zabbix-agent-6.2.6-release1.el8.x86_64 (zabbix)
    Requires: libssl.so.1.1(OPENSSL_1_1_0)(64bit)
    Requires: libcrypto.so.1.1(OPENSSL_1_1_0)(64bit)
    Requires: libcrypto.so.1.1()(64bit)
    Requires: libssl.so.1.1(OPENSSL_1_1_1)(64bit)
    Requires: libssl.so.1.1()(64bit)
    You could try using --skip-broken to work around the problem
    You could try running: rpm -Va --nofiles --nodigest
    I updated the openssl version to v1.1.0f:
    >> openssl version
    OpenSSL 1.1.0f 25 May 2017​​
    The error remains.
    Anyone that can help?
    Thank you.
  • Markku
    • Sep 2018
    • 1784
    Cent OS 7
    Are you sure you are using a correct package?
    Markku
    • Bs_sousa
      • Dec 2022
      Hi Marku
      At least it seems to try to install that version (see below the messages I get)
      >> yum install zabbix-agent
      Loaded plugins: fastestmirror
      Loading mirror speeds from cached hostfile
      * base: mirrors.pt
      * extras: mirrors.pt
      * updates: mirrors.pt
      base | 3.6 kB 00:00:00
      extras | 2.9 kB 00:00:00
      updates | 2.9 kB 00:00:00
      zabbix | 2.9 kB 00:00:00
      zabbix-agent2-plugins | 2.9 kB 00:00:00
      zabbix-non-supported | 3.0 kB 00:00:00
      Resolving Dependencies
      --> Running transaction check
      ---> Package zabbix-agent.x86_64 0:6.2.6-release1.el8 will be installed
      --> Processing Dependency: libssl.so.1.1(OPENSSL_1_1_0)(64bit) for package: zabbix-agent-6.2.6-release1.el8.x86_64
      --> Processing Dependency: libssl.so.1.1(OPENSSL_1_1_1)(64bit) for package: zabbix-agent-6.2.6-release1.el8.x86_64
      --> Processing Dependency: libcrypto.so.1.1(OPENSSL_1_1_0)(64bit) for package: zabbix-agent-6.2.6-release1.el8.x86_64
      --> Processing Dependency: libcrypto.so.1.1()(64bit) for package: zabbix-agent-6.2.6-release1.el8.x86_64
      --> Processing Dependency: libpcre2-8.so.0()(64bit) for package: zabbix-agent-6.2.6-release1.el8.x86_64
      --> Processing Dependency: libssl.so.1.1()(64bit) for package: zabbix-agent-6.2.6-release1.el8.x86_64
      ---> Package pcre2.x86_64 0:10.23-2.el7 will be installed
      Thank you for the help!
      • Markku
        • Sep 2018
        • 1784
        What was the zabbix-release package that you installed when using the instructions in https://www.zabbix.com/download?zabb...=agent&db=&ws=?
        Markku
        • Bs_sousa
          • Dec 2022
          1. For Zabbix agent I used the procedure on the link you sent for Cent OS 7:
          # rpm -Uvh https://repo.zabbix.com/zabbix/6.2/r...el7.noarch.rpm
          # yum clean all​
          # yum install zabbix-agent
          The machine where I want to install the agent is in Cent OS 7.
          2.Don't know if it's relevant but Zabbix server is installed in Oracle Linux 8:
          Zabbix server version below
          >>> zabbix_server --version
          zabbix_server (Zabbix) 6.2.6
          Revision 6981d8b729a 5 December 2022, compilation time: Dec 5 2022 10:20:52
          Copyright (C) 2022 Zabbix SIA
          License GPLv2+: GNU GPL version 2 or later <https://www.gnu.org/licenses/>.
          This is free software: you are free to change and redistribute it according to
          the license. There is NO WARRANTY, to the extent permitted by law.
          This product includes software developed by the OpenSSL Project
          for use in the OpenSSL Toolkit (http://www.openssl.org/).
          Compiled with OpenSSL 1.1.1k FIPS 25 Mar 2021
          Running with OpenSSL 1.1.1k FIPS 25 Mar 2021
          ​Thank you.
          • Markku
            • Sep 2018
            • 1784
            Ok, maybe someone with a CentOS 7 server can comment what is the problem.
            Markku
            • tim.mooney
              • Dec 2012
              • 1436
              I think @Markku's initial diagnosis is correct. It's not clear to me how, but somehow the client you're having trouble with is pointed at the wrong upstream repo.
              What does the following command output on the system:
              grep '^baseurl=https://repo.zabbix.com' /etc/yum.repos.d/*
              I downloaded the zabbix-release package you linked to, extracted its contents into /tmp and looked through the repo files it includes, and they all correctly point to /rhel/7/ areas of the repos. I also browsed the 3 repo locations that are enabled by that package:
              baseurl=https://repo.zabbix.com/zabbix-agent2-plugins/1/rhel/7/$basearch/
              baseurl=https://repo.zabbix.com/zabbix/6.2/rhel/7/$basearch/
              baseurl=https://repo.zabbix.com/non-supported/rhel/7/$basearch/
              and none of those directories accidentally contain any packages tagged as '.el8'.
              That's why I think your system in question must have (at one point) got a repo definition installed incorrectly, and it's still messing things up.​
              • Bs_sousa
                • Dec 2022
                Hi Tim,
                Seems you might be right!
                Below what I find when I ran the command you give:
                /etc/yum.repos.d/zabbix-agent2-plugins.repo:baseurl=https://repo.zabbix.com/zabbix-agent2-plugins/1/rhel/8/$basearch/
                /etc/yum.repos.d/zabbix.repo:baseurl=https://repo.zabbix.com/zabbix/6.2/rhel/8/$basearch/
                /etc/yum.repos.d/zabbix.repo:baseurl=https://repo.zabbix.com/non-supported/rhel/8/$basearch/
                /etc/yum.repos.d/zabbix.repo:baseurl=https://repo.zabbix.com/zabbix/6.1/rhel/8/$basearch/​
                Somehow it seems it didn't install the right repo.. it should be the one for rhel7 not 8!
                Any advice on how can I fix the issue?
                • tim.mooney
                  • Dec 2012
                  • 1436
                  That kind of error is really easy to make, so don't feel bad.
                  Fixing it should be very easy. You just need to remove the incorrect install for zabbix-release package and then install the correct one for RHEL 7.
                  1) remove the incorrect package:
                  # yum remove zabbix-release
                  You can answer yes when yum prompts you. I don't think it should prompt you to include any other dependencies, so it should be just that package that gets removed.
                  2) once the package is gone, that should remove the incorrect repo files from /etc/yum.repos.d. If for some reason it doesn't, and /etc/yum.repos.d/zabbix.repo or /etc/yum.repos.d/zabbix-agent2-plugins.repo are still present after the 'zabbix-release' package has been removed, then you can use the 'rm' command to remove (just those) two files.
                  3) get rid of any cached yum metadata:
                  # yum clean all
                  4) install the correct version of the RPM for 'zabbix-release', that comes from the RHEL 7 download area.
                  • Bs_sousa
                    • Dec 2022
                    It solved the issue!
                    Thank you both for the help!
                    Best regards
                    Bruno Sousa
