How do I monitor a service in Linux for when it goes down?
  • NewUser1
    • Oct 2022
    • 36
    I currently have the item and trigger configured as follows
    item: proc.num["isc-dhcp-server",,trace]
    trigger: min(/server/proc.num["isc-dhcp-server",,trace],5m)
    the goal is to get a notification when the service goes down for more than 5 mins. Is this the correct way to do it?
  • LenR
    • Sep 2009
    • 1010
    I think you're close, but the trigger min(....) needs " = 0" added.
    • NewUser1
      • Oct 2022
      • 36
      This seems to work but it doesn't resolve in Monitoring > Problems when the service comes back on.
      • tomijs
        tomijs commented
        You could try to add a recovery expression in the same trigger for it to resolve when it comes back online, that might work. Add a check for last received value and if it is 1 then the problem should resolve.
        last(/server/proc.num["isc-dhcp-server",,trace])=1
    • NewUser1
      • Oct 2022
      • 36
      I noticed the problem was I was looking for the service and not the process! got it to work now Thank you!
      • LenR
        • Sep 2009
        • 1010
        FYI agent2 can monitor systemd https://www.zabbix.com/integrations/systemd
        • wdw
          • Jul 2024
          Would you mind posting your full solution?
