Modiy Trigger discovered by Discovery Rule
  • andiwaldi
    • Jan 2023
    I have several Items that are being discovered via Discovery Rules created in a Template and then assigned to a Host.
    It seems like this Items that are discoved via a Disovery Rule are not able to be modified. In my Case i would like to change the Severity or add Tags. I am aware i can modify the Trigger Prototype in the Template Discovery Rule, but that would change it for everything. And i actually only want to modify certain Triggers.
    Is there anything i am missing and there is an Easy Way to change these Items?
    I guess cloning and deleting is a possability but that does not seem like a Clean way either
    I am currently using Zabbix 6.2.2. should that matter
  • Semiadmin
    • Oct 2014
    • 1625
    LLD override will solve this problem
    • Alessandro
      Alessandro commented
      It looks like I have the same problem. Could you explain how you would implement your advice? thank you
  • andiwaldi
    • Jan 2023
    I was thinking about that as well, but was hoping for an other Soltuion to directly modify this, but since we have quite a lot of Triggers and Exceptions for Severity then this will get complicated quite quickly, but i guess it is what it is thank you
