Custom Expression in Actions not working
  • RyanPrice
    • Jan 2023
    I have an action that alerts on a bunch of triggers for a specific group of servers. I want to exclude a specific trigger on 3 servers. The custom expression in the action is not operating properly. Screenshot below with the FQDNs of the hosts blacked out.
    This action is still firing for all triggers identified in A, B, and C.
    I have tried multiple iterations of 'Trigger does not equal' and 'Trigger name does not contain ...' (Trigger name does not contain Blacklisted, for example)
    I am on Zabbix 5.0.28
    I have seen a few other similar issues posted without resolutions. Anyone have any thoughts?
    Thanks in advance.
    Ryan​
  • tomijs
    • Jan 2023
    Everything seems to check out, the solution might be that you need to clear any existing problems, and perform a configuration cache reload by entering `zabbix_server -R config_cache_reload`.
    • RyanPrice
      • Jan 2023
      Thanks for the reply, I tried the cache reload and we are still seeing the same issue.
      Any other thoughts?
      • Markku
        • Sep 2018
        • 1784
        Try to configure a minimal reproduceable setup and open an issue in https://support.zabbix.com, that's the usual way to get something fixed. I see 5.0 LTS is still in full support until May 31st.
        Markku
        • Markku
          • Sep 2018
          • 1784
          As a workaround, try adding some specific (same) tag to each of those three triggers and then use a "tag not x" condition. Maybe it works with only one negated condition. (Just an idea)
          Markku
          • RyanPrice
            • Jan 2023
            Thanks for the ideas, unfortunately that workaround also sees the same issues. I have scheduled an update to 6.2 and will set up a lab to try and recreate this if that doesn't solve it.
