Zabbix 6.2 Item prototype in Web UI missing the SNMP Community string input field
  • kishorevh85
    • Sep 2022
    Hi, I am new to Zabbix. I have version 6.2 in my system. When I was checking the documentation page for 6.2 for low level discovery rule configuration (https://www.zabbix.com/documentation...ples/snmp_oids) I could see in the screen shot for the Item Prototype, the SNMP community string input text box is provided. However in the actual web UI, i could not see that.
    ref: https://www.zabbix.com/documentation...g%20screenshot
    Screen shot from the documentation page for 6.2:-
    Below is Item Prototype screen in the software in my local (zabbix version 6.2) the SNMP community input field is missing as below:-
    From lot of readings I could understand that the field is available in older versions of Zabbix and latest version of Zabbix this is removed.
    And the screenshot provided in the above documenation is not belonging to version 6.2 actual web UI Item Prototype.
    Can anyone who is using Zabbix 6.2 please confirm this?
    Thanks a lot!
    I guess the pic is not updated. SNMP credentials are moved from templates/items to host level. So it is OK not to have it on prototype config.
    There is a note on the bottom of the page (or actually on all pages)...
    "Have an improvement suggestion for this page? Select a text that could be improved and press Ctrl+Enter to send it to editors."
    • kishorevh85
      kishorevh85 commented
      Thanks for your suggestion. I appreciate.
