Filter specific eventlog data
  • ltep
    • Nov 2022
    • 42
    At the moment i'm able to retrieve logs from the Windows Eventviewer with a specific eventID into Zabbix with Agent2.
    The log result has multiple lines. I would like to use only some specific lines from the result like "Account Name" and "Client Address".
    Can someone guide me how this can be done?
    An example of a log file:
    Kerberos pre-authentication failed.
    Account Information:
    Security ID: DOMAIN\LAPTOP$
    Account Name: LAPTOP$
    Service Information:
    Service Name: krbtgt/DOMAIN.COM
    Network Information:
    Client Address: 192.168.10.20
    Client Port: 58412​
  • Hamardaban
    • May 2019
    • 2714
    You can select data using a regular expression .
    BUT! zabbix processes each line separately!
    Therefore, the first step is to remove line breaks - do the JS preprocessing step with
    return value.replace(/\n/g,' ')
    Next, use a regular expression (Regular expression​) like
    Account Name:\s(.*)\sService Information.*Client Address:(.*)\sClient Port
    to select groups with the necessary information and output them (Replace)
     \1 \2
    https://www.zabbix.com/documentation.../preprocessing
