Trying to make a trigger of a monitored logfile
  • look2
    • Sep 2022
    Hi !
    I'm trying to get a trigger when there is a specific entry in a logfile.
    I wan't to know when a specific user logs on.
    I have made the item, and it's working:
    type: ZABBIX_ACTIVE
    key: 'log[/var/log/auth.log,*eidadmin*,,,skip]'
    delay: 1s
    trends: '0'
    value_type: LOG​
    but the trigger won't work:
    expression: 'last(/eidadmin_logon/log[/var/log/auth.log,*eidadmin*,,,skip])=1'
    priority: WARNING​
  • Answer selected by look2 at 12-01-2023, 17:02.
    fvilarnovo
    • Jan 2023
    • 17
    You could check in "latest data" what kind of information the item has. As posted, it's going to be a string and you are evaluating numeric in the trigger. A good way to test this, is the "expression constructor" (test button) the value eidadmin is not equal to 1.
    So, what you probably want to do is use a string function:
    Or since you are already filtering at the item level the string that you want, what you could do is use a nodata function, while there are no new matches, the item won't trigger. If there are matches in X time, then it's a problem. This would allow to self recover as after the time passes the condition is no longer matched. For example:
    nodata(/HOST-TEST/log[/var/log/LOGFILE,alarm,,,,,,,],1m)=0
    Hope it helps.
    • fvilarnovo
      • Jan 2023
      • 17
      Hope it helps.
      • look2
        • Sep 2022
        I might not do this right, perhaps there is a better way to do it. Bur when the user logos on the machine, I get "Accepted password for eidadmin" in the item. When that happens I want a trigger. I will try the nodata option and see.
          • 5002
          if you need to find a pattern in returned text, then use find() function for that, not last... ie
          find(/eidadmin_logon/log[/var/log/auth.log],,"like","Accepted password for eidadmin")
          and then add nodata clause also, so it would go away in time... otherwise it never gets OK again
          • look2
            • Sep 2022
            It works with the answer from fvilarnovo​ Thank you very much.
